Anyone using the Daiso $2 apple cable?
fabianlau
Just bought this one is 1 m very identical to original..
Ps outlet still have alot:) three colour available as of today
tingyuan
which color most popular?
i bought blue and pink and it can fit in SWORD case.
Nakedtoes
IMM only got white n pink... The retractable one might not fit some cases
jownsftw
The cable was not really good.
It heats up pretty fast and the charging was slower than my original cable.
Cheap metal...
I've been using 3rd party cables for ages. I don't open my original cables. I can assure you that every cable i've used from various sources ebay/gmarket/daiso all is the same time for charging. No difference...
tingyuan
ps still have alot pink, blue, white cable. retractable one cannot fit SWORD case.
aster1
Loads of availability in all colours at Daiso Ion.
I like these cables, they are cheap but solid and get the job done. Will never pay more than $2 per cable ever again... :)
tingyuan
i bought 3 for $10. but iphone will prompt "yellow ! mark this charger not support this accessories" after that not able to charge iphone. is it iphone going to spoil soon?
LobsterX
you're taking about non-daiso cables right?
keep the the topic.....:D:D:D
i get that "warning" in the following situations
1) non apple charger, ie made in china ones
2) i used a 1.8m usb extension as the 1m cable cannot reach behine my CPU CASING[not CPU.... CPU refers to the PROCESSOR on the motherboard. a common mis-conception these days]
3) iphone charging port dirty
4) RARELY..... battery damaged....... only once..... on my 3G:D
Veloso
I got the shorter one and the blue one. both working fine all these while. :)
palmtungsten
Also bought from ion orchard recently.. Has stock for white, pink and blue cables.. Nice and good quality cables
jq75
Charger output must be 1A
