ASUS Transformer Prime
guile
Applied as well, looks like we have to remove the Sleeve each time we want to use the dongle. Oh well, a little sacrifice i guess.
Slash1
got the prime some while ago, love everything about it. except that I'm facing some issues for the usb ranger speed, it is insanely slow....
so far tried:
1. pc > usb dongle > tablet internal memory
2. pc > usb dongle > tablet external sd card
3. ext hard disk > usb dongle > tablet
4. ext hard disk > dock usb port
etc....
now the only way I'm using is transfer the files to the micro sd externally then insert back to tablet. pretty non senses to me unable to fully utilize the tablet 32Gb internal memory. i had an acer iconia A500 which has much faster transfer speed.
did some research found that some users also same problem but doesn't seems to have solutions.
any bro dealing the same prob?
kyleongwl
so far tried:
etc....
Since Tf101, it had been this way..
Remove SD card and copy necessary to it.
From SD, copy yo internal memory if needed.
This is the "fastest"
hamudi
erm..it did crack.
but just gonna bring down anyway.
its fragile :(
Wah so suay ah...
I put my transformer prime in my bag while longboarding, fall down several times liao, but my prime still ok.
coldsea
abit side line, anyone know now prime is around how much? and where toget it? saw at funan... $899..
yhw22
That is the price everywhere is selling. Get it while got stock, as no more new shipment of prime anymore. Source from Asus Singapore fb.
phenol
huh no more in production?
If you are not in a rush I suggest you wait for the next batch of transformer prime series. Since they don't do 3g, wifi is very important but it is not performing up to standard due to the current aluminium casing. On another note, Anyway I didn't expect GPS dongle to be so big. Since when are things supposed to be big nowadays. Lol.. would be good if they come up with wifi dongle something like thumb drive size
kyleongwl
maybe the BIg 3g dongle will helps boast signal thus wifi better :p
Fifa03fan
My Prime went dead after charging it and powering off (to fix a vol up button problem), vibrates after 10 seconds when trying to power on. But screen is blank. Anyone faced this problem?
kyleongwl
sound familiar...as my was battery dead.
Wnet over to tai Seng and sent in for battery replacment
