Galaxy Note Accessories
Akai Ryu
supergmail
Finally got my white note a casing after started reading from page 1 :s22:
Got a white Tridea book case on tuesday. Build quality i would say 9/10, lets see how it turn out after 2-3 months of usage.
Downside is the cut slit for 1 card in the flip cover is abit slant not straight:s13:
The magnet flap to hold the flip cover is not that strong, just enough to hold the flip in place which i like about it cos i can just open up the cover without lifting the magnet flap.
Protects around the phone and easy to remove stylus from the cut out hole.
Will try to post pic at night.
The Tridea book case got 2 version right? one with the magnet and the other without.
Akai Ryu
supergmail
i am thinking of getting sgp glas and 3m privacy filter on it, anyone know if i should paste the 3m privacy filter first then follw by the glas or glas first then follow by 3m?
Vulpix
Moderator
Moderator
Wait, what? Are you kidding me?
criminalz
Glas then 3m.
Of course, that protection alone is insufficient . I would suggest, have a layer of transparency, follow by shrink wrap to keep out water , then lacquer to maintain the brightness and finally with a generous roundof bubble wrap for fall protection.
