The Official Xperia S thread
rssd21
the matte one also will attract fingerprint or they only have glossy one?
Usually fingerprints will not be obvious on matt sc but your screen will be dull. Clear or glossy sc will not make your screen dull but will have obvious fingerprints. Check out the features for dataflex hi-res, think of it as a mixed bag between matt & glossy/clear.
Outstanding Features:
- Anti-Glare
- Anti-Reflection
- Anti-UV
- Anti-Fingerprint
- Superb Protection Against Scratches
- Enhanced Material for Strong Protection and Long Lasting
- Non-Glue Adhesion Provides Bubble-Free Installation
- Improves Screen Sensitivity
- Provides High Degree of Clarity
- No Distortion to Images
- Reduces Glare and Reflection
- Prevents Dust and Grimes
- Abrasion and Chemical Resistant
- Washable and Reusable
- Quick and Easy to Install
- Removable Without Leaving Residuary Mark
Dataflex_screen_protectors
teh__o
- Anti-Glare
- Anti-Reflection
- Anti-UV
- Anti-Fingerprint
fwah power! is this what you are using korkor?
rssd21
Too bad, I cant wait. Im using this instead, clear sc that is only better than stock sc.
rssd21
how much is this? did you apply yourself?
$16.99 (exclude shipping) - 2 pieces sc, 1 squeegee & 1 wiping cloth. Apply by myself, not too much trouble since not much bubbles while applying. So far no scratches although I always put my phone in pocket.
teh__o
i very scared those must apply myself one, got dust or bubbles damn obvious
worst is when the end part dont adhere properly to the screen
ragnarok95
Senior Moderator
Senior Moderator
Dust use the provided tape to remove. Bubbles use the provided squeegee card to remove.
rssd21
Initially I was worried too but so far I got some experiences with applying sc & this particular steinheil sc is quite easy to apply. Of course, in clean environment & will little bubbles trouble.
If not, pay a bit more to shops & free yourself of DIY worries. :D
ragnarok95
Senior Moderator
Senior Moderator
after i apply the sp liao, got dust trapped underneath
use tape to remove? the sp can keep take out/stick back one?
Use tape to paste on top of the SP and lift up. Use another tape to remove the dust. Then paste back. Got bubble use the card to remove.
teh__o
and it helps when the phone is new right?
some of those i bought last time they dont provide application one like those sanrio ones lor
got try before but got one part like wont adhere to the screen no matter what
and there's no dust there already, not sure if you know what i mean
pker88
if cant do it ourself
like me
i go pay for ppls to help or buy SP from shop and ask them to paste lor
easy does it
anpanbun
not sure on x's sp. but carlsover say x's sp has arrived
but my arc s is $10 glossy type
they
got matt and high Res matt
means the high Res Matt more clearer but still got matt coating ao lessssr oil prone
Thanks, pk
globalzorian
Waiting for them to let me know if the replacement of the screen had arrive. My yellow spot like quite big liao...
After receiving back my handset back from the service center with the replaced LCD (which also still has some amount yellow tint), somehow, the long absence of XS taught me to become less sensitive on the yellow thing... Life without XS was more of a nightmare relatively. :D
Igene
Hi all,
My English not very powderful so need some advise here:
From Sonymobile:
Important information
Please note that you may void the warranty of your phone and/or any warranty from your operator if you unlock the boot loader.
What does that sentence mean huh? Will or will not? 'May' is a bit vague leh... :s22:
dreamz13
Yup if it's not so serious, I guess we can live with it. Like I notice some discoloration effect near the top of my phone too when the screen is displaying some white pages, but it doesn't really bother me too much, since I can't see them most of the time.
anpanbun
Yeah, I can see that, how it was a nightmare for you LOL. Enjoy the phone
globalzorian
Hi all,
From Sonymobile:
Yeah, IMO, the usage of "may" indicates it's not a sure thing but on the other hand, it also means you can't blame them if they suddenly tell you that your warranty is no more. :s13:
hush66
Hi all,
From Sonymobile:
I think they intentionally left it vague by using the word "may" instead of "will". That said, someone mentioned before that they had sent in their phone for repair even though bootloader is unlocked and Sony fixed the phone. I think as long as the problem is not directly related to or a result of the unlocked bootloader (e.g. hardware issue), they will honour the warranty and repair.
