globalzorian
- Feb 21, 2012
Mean global kanna trolololol by sony ~![]()
Haha, I'll send it back in again much later for a second replacement.
wah jialat. any other SP u can recommend?
but from their database they will know that I have requested for the BL unlock code. no?
True but I highly doubt that they will check before servicing your phone. Someone from XDA (Singaporean) reported that he sent in his phone for repair and the bootloader was unlocked and even had a custom ROM and kernel (boot screen animation was different), and SE fixed it anyways.
why you need privacy sp when sony built in for u already
I never used privacy screen protectors before, but I thought the concept was such that others cannot really see the screen from the sides?True but I highly doubt that they will check before servicing your phone. Someone from XDA (Singaporean) reported that he sent in his phone for repair and the bootloader was unlocked and even had a custom ROM and kernel (boot screen animation was different), and SE fixed it anyways.
time to unlock and flash![]()
The pre-applied screen protector is a privacy screen protector? But I can still view the screen from the side.I never used privacy screen protectors before, but I thought the concept was such that others cannot really see the screen from the sides?
yalor I will give XP some chance but only woeey of form factor same as x's
plus smaller battery cap
wonder how efficiency is the new CPU and LCD too
maybe for gb OK but ics might suffer
Looks like we already got a volunteer here![]()
well, if i am gonna use XS for long, i won't wanna port to ICS also. cos i like the way it is now. battery life so shiok.![]()
LOL, Doomkernel is out, and we also have a new custom rom that I like. so going to try it
hopefully batt life will stay the same if not better after ICS upgrade.ya i agree the current battery life is damn good. but when i was using the Arc, I switched to ICS and it was actually better den it was on GB.
but it is not a good comparison because of the different apps and all that on the phone
