- Mar 9, 2004
You can crack the top with bascially any headphone. Dun just single out the S4 dude.
u dont try ur luck. physical damage is not under warranty. they will replace for u foc is out of good will.
he will try if u lend him ur s4. ahaha..
u put the hp in pocket or bag and the case crack?He can use his current headphone le...unless he blind cannot tell the diff???
Cannot be la...can reply mean got eyes can see le ~![]()
hold in hand or use wireless.so basically i cannot use any 3.5mm plug earphone/headphone to listen music using this?![]()
u changed the screen too? the screen is attached to the case hence u got a new case for the crack?
now early May liao lolTheir manager told me lcd panel is here but casing haven. Casing ETA early MAY. zz
Their phone are free to use. But are those simple usage phone, not smart phone.
