Galaxy Note Accessories
criminalz
Omg!!!! Super bad mistake to recheck back this thread. U guys really freaking cruel. Now decided to kiss s3 goodbye and stick to my note then came in to check some minor accessories. Bad bad idea. Sooooooo many things. All I want....
Whizdom
*offtopic
is it me alone that i find using 3rd party micro usb cable will charge very slow and sometimes the charging percentage will drop? whereas using a samsung usb cable,the charging percentage went up and charge quite fast
theory_87
*offtopic
1st, are you charging off wall charger or computer usb?
2nd, if wall charger, are both charging done with the same charger with different usb cable?
Akai Ryu
*offtopic
i use a 2m fr DX....doesnt seem to have any effect, can rule out that length of cable will affect (?)
tried nokia's, there's the screen sensitivity issue
Akai Ryu
Donstar
fabianlau
the chrome will go very well with the chrome sweet armor gnote
Vic? if u see this, can keep a look out for it at hk? Pic fr some hk forum but i can only find this back cover fr some jp site which does not ship abroad....:(
Edited: found the source...made of plastic........then again may not be a bad thing coz metal back cover might affect signal
Where to get this ? Look good
Akai Ryu
Yep, by tonight or tomorrow will confirm location. Gotta be sure I will not be called back to work first. :s22:
Tomorrow lah, let u get over ur high for the estoc and navjack, and god knows what other hoots lol
Whizdom
wall charger.
same both charging done with same charger but with different cable
usually i'll use the same original charger and samsung cable while im at home the charging is fast and never drop
then i bring my charger with a 3rd party cable to school . it take quite a while to charge and the percentage drop
adix_82
MHL Adapter that comes bundle with a HDMI cable. Any bro need more info can PM or contact me.
Akai Ryu
the one i saw is without the samsung logo and is plastic chrome and gold....must check if its the same item first
this is pic fr some jp site....looks similar to the hk one but ish marketed as metal back cover......have a feeling its plastic too
the chrome goes well with the white note's bezel
fast_asleep
Vulpix :s12:
(the navjack case)
is the front shiny?
does the front cover stay closed to protect the screen if phone was dropped accidently?
