The Spectacles Thread.
yamapi
Quote price for ray ban frame 1.67 index emi lens for $350 - 400 is good bargain or gana chop?!
jonathanckh
Just prescribed a pair of tag heuer half rim specs with crizal 1.6 index for 935 at mee mee optics. Collecting next week! Cant wait!
den888
How much does it cost to make a pair of Zeiss Framefit freeform 1.67 lens with Photofusion? About 400 degrees right and 300 left. The rest all pretty normal.
xiaokaka
I think u trying to say Carl Zeiss 1.67 Individual PhotoFusion SV lens..
Prices i forgot already... Prob looking at least around $850~
I only remember PhotoFusion FrameFit 1.67 Progressive lens @ $1700~
chanzhf
Should be from $300+ all the way till $1800~ish
Depends on brand and Design..
thanks. my eyesight is about 750 on both sides. I took the plunge and ordered a pair of korean made 1.74 lenses for only about 80 SGD :s22:
Will post some reviews upon receiving it.
xiaokaka
If $80 den ok la.. if quality not so good also wont heart so pain..
smelly smelly gt Anti-Reflection coating good already
den888
Yes it should be framefit individual not sure what is the actual name but they are those customised progressive type with Photofusion.
xiaokaka
Carl Zeiss Progressive FrameFit PhotoFusion 1.67..
Looking at smelly smelly $1700..
2-3 weeks to arrive in sg.
nicholas_lee31
hello everyone,
i would like to get sunglasses lens that are prescriptive lens possible?
for wayfarers...
want to get cheap kind, dont have to be crizal or wad...
know of any good shop to recommend?
Seannie
No, I dont think its good enuf. If your degree is 750 u need to take double aspherical design, am i right xiaokaka? $80 korean lens is cheap but vision is not good. And AR coating sure v lousy. Even normal jap lens like OSA brand's AR coating spoils after 4 mths. I dont dare to say for korean lenses. Im surprised shops in sg nowadays still sells you such lens.
$80 honestly speaking cant even last you one day of living expenses in sg. So what to say for a pair of lens? U can only imagine the quality.
Seannie
Wow! Never thought that lenses could be so expensive!!! :eek:
Hey citiguy, not only are lenses expensive, everything else is expensive now. Even a hdb flat can cost you more than 500k and up to $1mil whereas many years back hdb is supposed to be affordable & much cheaper.
So seriously speaking, $1000 for lens will be considered the minimal in the years to come. Imagine sg inflation rate is the highest together with hk. U just got to work harder to earn mre $. Investing in a good pair of specs is much better than you needing to change your lenses every once in a while else you got to live with seeing the world through spoiled AR coating lenses.
Seannie
Take out lens >> Push the ends into inner grove >> put back lens
Hais, you still don get wat im trying to say. wat i mean is that the nylon may have been scatched or run over by sme metal things or watever that causes fine roots of the nylon to come off.
Anyway, i will just live with it and wait till the lens spoil before gg back re-order new lens to fit in at the same time request them to replace me a new nylon thread. That wil most likely be in a few yrs' time. If go back to shop to ask them do anyting now, im afraid they will further spoil either the frame or the lens in the midst of re-doing. I better save the risk.
Seannie
guys, anyone knows the market price of 1.74 index lenses in singapore?
realistically, u don really need 1.74 lens, esp if you choose bigger size frame then the thickness would have made no difference at all.
1.67 is really good enough, make it a dbl aspherical and it will be almost like a 1.74, and much clearer.
