Re-contract Singnet 10 Mbps?
guntorasuk
I was on an old 3mbps plan previously, using a non-wireless modem.
That's why they threw in a wireless modem for me.
Maybe your current modem is already wireless, so they refuse?
Or it depends on individual CSO?
Ya, I'm on the old 8mbps speedtouch modem, wired, told them and still they refused to give me the wireless modem.
jas1701
Is your Speedtouch model 536v6. If it is you can get the linksys wrt54g to connect to it and use the linksys as a wireless router. Both combine is even better than ST give you the 2wire modem. The reason is the 2wire wireless signel tends to drop when in operation.
ST gave me 2 sets of the 2wire modem when I re-con and both have the same problem. Bring and change a new set also same problem.
guntorasuk
Ya, my modem speedtouch model 536v6. Ok thanks for yr advice, think I better get the linksys wrt54g u recommended. Anyway there is no need for bridging right?, as what I've read in other post. I'm not technically astute, how should the connection be?
Michael Faraday
just check with all the old bird, here, is it possible to get a new sign up of 10mbps at recontract price, the webby din list this package anymore :o
jas1701
The setup is very easy only, if not wrong is 3 steps only. But I cant remember the steps as the document is in my office. The steps I have input somewhere in the thread but under which post I not sure.
jas1701
guntorasuk, ok manage to find it. Follow below steps.
1) ST536: router mode, DHCP turned on
You have to ensure the above can connect to internet by RJ45 cable before proceed to step 2
2) Linksys: DHCP turned off, RJ45 cable from ST536 is plugged into one of the LAN ports (not WAN/Internet port)
As I said before in my previous thread, these 2 combinations work very well compare to the 2wire modem.
guntorasuk
Ok thanks, just trying, I access the ST536 using 192.168.1.254. Is this correct? But couldn't find any options for router or DHCP. Where is it located?
I'll get the linksys router soonest possible but anyway how to access its configuration? TIA.
jas1701
By default the st536 dhcp is "ON". Just set your linksys will do. Default for linksys is 192.168.1.1 and if you reset it you can go straight into the menu without any password. Linksys router got quite a number of version. My is ver 7.
guntorasuk
Hey jas1701, thanks for all yr advice n inputs, appreciate it very much. Thanks.
tyk123
Re-contract 10Mbps plan, manage to get Aztech wireless ADSL modem 1015EW(S) thru some persuasion.
jas1701
I got it same model as you but not sure about the version. But 1 thing the wireless signal sucks leh. I disable it and use my old linksys wrt54g as a wireless router. Signal is so much better. :)
yixiang1
Why wrt54g seems to b the classic router huh... Like at least around for 7 years liao yet many still say its signal strength and stability beats many newer routers.
Amazing leh...
jas1701
Amazing leh...
Been using this for 8yrs since my SNBB 1MB plan. Then upgrade to 3MB, 8MB and now 10MB still using it. Too bad is if I switch to FO, don kn what router to use liao.
lasnoblur
gt the deal at 23.45 for 12 mths too.
no free modem but assured 1 yr warranty for current modem.
touchme
Looks like St not interested in ADSL anymore.
From 23.45/12mths with phone waiver&modem to no waiver/with modem to no waiver/no modem., all within 1 year.
harky
still got $23.45~~ u tell them u want to cancel they will quick give u $23.45
but i had already cancel my.. i going to fiber liao .. dam fast
