China Tablets to recommend
chap88
some apps not present in gplay?
Hi Folks, after playing around with my new pad and d/l many apps etc, I am starting to experience general lag. This maybe understandable consequence of adding so many apps/ebooks/etc.
Another thing I found is that the battery indicator is eccentric - it displayed 47%, then 1 hr later cannot even boot. I plug in charger, and turn on - it shows 37%. But i read in the earlier threads that this can be resolved through "reset" procedures so that the os recognises the zero state. However, I am not complaining cause I did give me at least 6 hrs of movie watching before it ran down to 47%.
One last find - some apps are actually not available on the gplay. I confirmed it by logging in from PC gplay - eg. Rockplayer. Is it possible that I have limited access to gplay because it is a chinapad? Any solution to this?
cheers!
kyleongwl
cheers!
could share what is the exact model?
chap88
It is a generic model bot from sz - it resembles the EKEN A90.
The specs from the settings menu are:
Model: P90
Android version : 4.0.3
Baseband Version : 1.1
Kernel: 3.0.8+ w-w-w.yfgps.c-o-m #37
Build number : mw07-eng 4.0.3 IML74K 20120425 test-keys
UUID: aaa2a551eb1d7730
seasonscrystal
Model: P90
mintpie P90?
mintpie£¨ÄáÅÉ£©¹Ù·½ÍøÕ¾
Ö±½µ160£¡ÄáÅÉP90ƽ°å 988ÔªÏÞʱÇÀ¹º£¡_ÄáÅÉMID_MP3ÐÂÎÅ-ÖйشåÔÚÏß
Lag after u packed the tablet with stuffs is common.
Battery normally we'll try drain it to low battery during the 1st couple times of use then do a full recharge. It could be a firmware bug too.
I believe mintpie did not mod the build.prop as some apps do not recognised P90 or A10 processor. So you need to mod the build.prop to fool playstore/market to think it's another device like SGS2. Look at slatedroid for more info.
chap88
Seasoncrystal- yes, you are right - its the mintpie P90 after searching the internet a bit.
Back to the apps that wont install: I scoured the web for some time and found someone (slatedroid thread on Mintpie P90) that he just installed some apk to get gplay to install the apps that couldnt install initially.
So I went on a hunt for arcmedia.apk and rockplayer.apk. I was lead to all kinds of strange sites with no success. I need your kind help on 2 things:
(1) Can you tell me if this apk route will work better than the build.prop mod (I am afraid of messing up my new apad b4 I get to enjoy it to the fullest!)? If so, where are the "usual" places i would find such apks freely downloadable.
(2) I rip some dvds to h.264 (mp4) format so that I can (kill 2birds) load to ipad (for wifey) and to apad (for me). It played on the ipad but refused to play on apad - that's where the abovementioned 2 players come in. Any advice on ripping or format that is dual ios & android?
Thanks in advance...
kyleongwl
as apple product only know m4v or mp4, i guess u need to convert to such format...keep to 720p.
Frame rate = 24
Bit rate = 2000
seasonscrystal
IMHO, build.prop edit will be better if you know how to. If you don't maybe try getjar which is like alternative of gplay. As for free warez apk, you are on ur own;)
Snowblind
Hi guys, just curious. How's the battery duration for the China tablets u guys have. Battery usage is WiFi, forum web surfing and abit of youtube. Thinking or getting a cheap 7 or 10 inch tablet to use while my main tablet is charging. Thanks.
chap88
Frame rate = 24
Bit rate = 2000
Ok, thanks. I will try to rip to that format. BTW, I am using handbrake (no watermark but slower) and DVDFAB (has watermark but faster). Will let you know if this can solve the apad issue.
chap88
Hi, I "stumbled" upon the apk:s13:. Installed fine...but still wouldnt play my mp4 files although it plays the others. I will try to experiment around a bit more and last resort-build.prop. Thanks!
chap88
Hi, mine is 9.7inch- about 1.5wks old. As of today, the battery runs for about 5hrs active (2.5hrs of movie, 2.5 hrs messing with setting, gplay and surfing) + the rest standby hrs- I recharge every 2 days. Recharge time is very long - 5hrs to get to 100%. But having issues with the battery indicator (see my other thread). Still monitoring the battery life and will update if there are any significant changes.
Snowblind
That's quite good actually. Wanted to get the ones vi40 earlier this yr. Missed the chance and just forgot. Might go for the ainol 7", seems like New models coming up.
touchme
Got myself a chuwi v8HD, quite good actually. ..its battery, touch response,speed and price..Maybe its just my past bad Xp with mic tabs.
Waiting for Ainol Nova7 tornado, dedicated for car: music,maps, movies, karaoke, carcam, etc.
seasonscrystal
u can't play mp4 file? By right Allwinner A10 default player can play liao UNLESS that mp4 is encoded with a rare codecs. Try rockplayer.
Older China tablet (2010 and before) all lacks the technology. They were using resistive screen, poor power management, lacks RAM, lacks decent GPU, etc. But since days of Amlogic M (before RK2918), everything improved a lot liao.
Why go for Ainol Novo7T? It's like a downgrade of Novo7A. Novo7T uses Amlogic M3 which came out a month after A10. It never gain much porpularity then, mainly cause Allwinner A10 is a better chipset for medias.
Even Amlogic M6 aren't as good on benchmark compared to RK3066.
Might be more worthwhile to get Gemei G3 or G2 which is abt the same price as Novo7T.
chap88
Rockplayer rocks!
Seasoncrystal & kyleongwl- thanks for all your suggestions.
Found the rockplayer (apk) - now all my videos are playing superb. Now I just need to do a one time rip of my dvds into ipad H.264 and then transfer to ipad (for wifey) and apad (for myself) and we both enjoying movies on the go:s12:
BTW, Under settings, there is a "system updates"- I have been pressing that button for updates since day-1 but it always returns that your system is up to date. What I am curious about is that it always returns instantaneously to report that there my system is up-to-date.
touchme
Mx player seems best for me so far be it A10 or M3.
N7T for car use only. No need hi-res, can play music, kars, pics and vids, quick map search can already. No reading/surfing. No GPS needed in Sg.
Cheap cheap $100, put in car, no scare window smashed and stolen.
kyleongwl
Dont bother to use the system update..dl frm web
PCI_Slot
Tempted to buy an ainol Tornados or Auoroa from expo electronics fair. Should I? 219$ and 179$ if I remember correctly. Nw I resting outside. Nv take tje flyer. Or better deal somewhere else?
MMZA18
Dear HWZ bro / sis, Stay away from them (CH2)
1) Dont support them, the more you continue to support meaning to given chance for them to corn more consumer.
2) Buying from them or road show come from same importer which is reknown for non-existent support or warranty. http://forums.hardwarezone.com.sg/64575194-post471.html
3) they only care to make profit, they dont concern care about consumer. :(
Past Record >
last year 2011 - selling refurbished set Novo 7 advanced back to customer
this year 2012 - continue selling refurbished set Novo 7 Aurora
(there are many more bad records before that.)
should able to get it for aurora and tornado at $140 & $200 in local market. their price are rip off. :(
serene_vsn
Hi... I'm new to tablets, am thinking of getting the Teclast A15, 9" tablet.
Anyone can give some advise? Thanks!
