Galaxy Note Accessories
davi502
Need feedback on the general area of where ur phone feels warm when phone heat up. The area right under the camera feels warm when under prolonged use. Batt area with goni feels normal, hope it's an indicator that's cool pad's working lol
For me, only the area underneath the camera lens feels hot.
samson1
sorry ah not here to pour cold water but are all these non-samsung brand batteries safe to use? cause i always heard from others that its better to use the original brand's charger/battery else the phone would spoil. 2800mah is definitely an upgrade to the current one so im pretty much tempted to try this one..
Spoil? Unless it explodes loh. Anyway 3rd party batteries should be okay since the lithium battery protection circuit technology should be pretty stable by now. Got a momax battery for my galaxy S and it is still fine. Will check this one out when it arrives.
Akai Ryu
Sgp for note have in Challenger. "Spg" never hear before hahahaha
creampuff
i do not use the cool pad..but that normally where my SGN heat up first after a long usage..the camera area is usually hotter than battery
Akai Ryu
thanks for feedback.....needed to know whether it was the whole of the back area which heat up or part of it.
Goni batt area feels cool whereas under cam can feel the heat...so presumably working (?)
Erntehelfer
New bumper from Korea, dont think its at gmkr yet coz just release
Hello from Germany,
this bumer is amazing. You guys are so priviliged in Singapore. A paradise for accessores for the note compared with Germany.
Is the bumper from Patchworks?
I would love to order this bumper (if released) and would like to contact the company directly because Gmarket doesn't "work" with Germany shippings.
Tnx,
Jens
Akai Ryu
Hello from Germany,
Tnx,
Jens
hi jens
u can probably keep a look out for it at ebay....they do have patchworks authorised sellers there but it will most definitely cost more
It is stated that first batch will be out from 2nd week of June.....u may wanna contact PW via their website or FB even
