FineVu CR-300HD
commonjunk
Just installed cr-200hd, seems ok.
Yesterday some ahole reversed bang in my car, bumper got scratches and number plate is almost broken in half :s22:. not sure how much is damage behind number plate :(.
Cost me quite a bit around 530 with installation and directly connected with battery.
Naga Siren
hi guys,
can i check how do you load the videos to youtube?
as in, when i play the video, it's all in 1min files, how to combine as one and load?
ZhuTou!
Too ex already
Cr200 is older model
linzw00
I put front and rear so that I can capture the person zoom from behind, dangerously and cut into my lane, so that I can claim them with both videos. ;)
Just an explanation why I want the rear one. Especially when cars try to overtake you to exit, or just want to be infront of you.
It helps.
good point, never tot of installing it at the rear. i got a china made supposedly HD but i can't see the darn number from the side as the car passed by and even when the car is directly in front of you but at 1 car dist away. the only time you can see the number clearly is there is no dist in between.
but just to side track a bit, why would a driver want to dangerously zoom from behind and cut into yr lane in the first plc? i am not angelic driver myself nor do i consider myself as one of those hooligan type. but there were occassions that i do that stunt. (ie, zoom from behind and cut into the lane) but the typical situation when i do that was when driver is hogging 1st lane and no matter what i tried, horn, highbeam refused to move his arse off the first lane.
just concerned bcos then i run the risk of being video clip by you next time! if i zoomed by you and cut into yr lane. :s13:
also, i read about the heating issues wif BV and other better brands.. actually beside the just the heating, are there any risk implication or quality issues resulted from the heating? thks.
longman77
How much is the ITD-100HD & FineVue CR300-HD?
wonder which have better PQ on nightview/raining night
chunxi
which workshop is recommend for installation as in reasonable price & skillful ?
prefer in amk/serangoon north area.
fighter_foo
I installed one of this with dual camera. Just plug n play, normal cigarette lighter ...
dvr.vshub-partner.com
Cheaper than most of those mentioned here, quality of video is also acceptable imo.
gaolow
just mounted another ITB-100HD on my rear windsreen..see videos below (watch it in 1080p)..
another thing..with that camera on the rear ..you can used it as reverse camera when parking...
u need to connect to a small monitor..a small external 7" lcd scrren , GPS or HU
Used as Reverse camera..for easy parking
Night driving recording..from rear view
Tunnel driving recording..from rear view
Stationary parking recording..from rear view
