Cheapest Android Tablet option
kyleongwl
Hi guys,
after attempting to flash my G3 to ICS, it can not longer turn on. Whenever i plug it into my computer, the popup from livesuite to choose upgrade mode(format or don't format) appears. Seems like my G3 is still in update mode(which i entered by pressing vol+ button while spamming power button.
Help anyone?
tried to redo the upgrade again.My G3 is in GB...not into looking good (ICS) unless its good
klmok
seasonscrystal
I came across this 8 inch 16:9 tablet costing RMB$599 and the review from china website:
Íæ³öʱÉÐ ìųö×ÔÎÒ ITOOS I8 °Ë´ç¸ß·ÖÆÁÄúµÄ×î¼ÑÑ¡Ôñ - itoos - iMP3ËæÉíÓ°Òô
I was looking for 8 inch tablet mainly for ebook, web surfing and maybe light gaming and can be easily carry in a bag (7 inch too small and 9 inch is too big). Galaxy Tab 7.7 is too expensive although it fit my requirements. So I have ordered the itoos i8 and it's on the way now.
Itoos I8 looks like running on Amlogic M3 which is same as Ainol Mars & Tornado. 599 RMB looks like a good price, if the screen view angle is as good as what was posted in IMP3, it'll be really worth getting.
Do give us a review when u gotten it :)
laironpark
To those looking for a cheap 7" tablet may consider this:
Yuandao N12, only RMB349
http://detail.tmall.com/item.htm?spm=141.27931.253453.12&id=15193027432&_u=molk7km0daa
Hyruga
Anyone knows what i can do with my spoilt MOMO 11 tablet (unable to start)? I asked sgshop but they keep saying cannot contact the buyer and they can only contact the buyer via QQ. What a load of rubbish.
I also do not have the chinese address.
Anyone wants to buy from me? Selling spoilt MOMO 11 with charger and all accessories. $100.
filepillow
just got my Gemei G2 from 65daigou today.
my set seems to have problems with wifi via M1's broadband modem. Can't even load a webpage.
Using personal hotspot from my phone seems to work better although it still gets disconnected a lot....
anyone having G2 have any comments?
System info
Model number: gemei G2
Android version: 2.3.4
Baseband verison: 1.04
Kernal verions: 2.3.6-android root@ubuntu #32
Build Number:
gm_g2-eng 2.3.4 GRJ22 eng.root.20120326.163459 test-keys
tnecniv
Hi anyone using Bmorn V15 tablet? anyway to put custom rom for mic tablet? where can i learn to mod?
corp_cho
System info
Build Number:
Been using G2 since Feb. Wifi is gd for me
Corsabrin
hi all, im looking for a tablet mainly for reading books,microsoft office and light gaming. important is must have decent battery life, for me about 5-6 hrs with wifi on should be enough. budget about $140 +/-. Anyone got any tablets to recommend?
Thanks in advance.
Force89
Thanks in advance.
Hmm, for your budget, probably can try 7" A10/A13 tablets. Prices for these tablets have dropped significantly with the introduction of the newer dual core tablets.
yxezme
Tablet : Cube U10GT
Is this model (Cube U10GT) available in Sim Lim ? What's the price like locally ? I'm contemplating to get it directly from cube-tablet.com. The only thing holding me back is the shipping cost, which is pretty significant for just for buying one tablet. Has anyone bought anything from this online site? reliable ? :s22:
Force89
You can probably get a newer model now since the U10GT is an old model. Can consider the newer 8" tablets which I posted in an earlier thread.
yxezme
I'm budget-conscious and meant to just try out some value-for-money android tablets first. So, don't mind even if it is not the latest ..Where is the thread mentioned by you. Can't seem to find it.
Force89
Corsabrin
hey force89, i seen your spreadsheet, apparently the ITOOS I8 dual core seems like the best isnt it? dual cameras, highest mah battery and relatively cheaper price. Any downside that i seem to be missing?
also, which web can i buy this? aliexpress / tmall?
Corsabrin
Force89
Yup. Specs wise the above tablet is one of the better choices. Just that it is not as established compared to Onda, telecast, Ramos etc. Software updates is also an important factor though newer models tend to get phased out quite fast.
