Hi and good evening to everyone.
First of all sorry for any inconvenience regarding the delivery. We uses two private courier to deliver the Tablet according to the schedule date that we confirmed to each of you at the time we called. Sad to say that in some cases it is already out of our control if the delivery was delayed or moved by the courier company itself, the courier never inform us about it that is why you never hear any update from us regarding such issues. We can only assure you that the collection is been arranged and pick up by the courier at the proper time.
Regarding the unit shutting down automatically, we apologize from what you have experienced. Please give me some time to check this on my part to really verify what had caused the problem, for now we can treat it as a bug.
For those who are affected by this, please let me know:
-What is the percentage level of the battery before it shuts down
-Is the issue repeatable, always or once in a while.
-Help me know what are you doing or running when it shut down.
I will make this case as a priority and check with our developers in order to give you a concrete answer and a solution as soon as possible. Sorry for any inconvenience.
Feedback: Unknown (It could be fully charge, around 80%, less then 50%, less then 30%), and after shutdown, cannot power ON normally by pressing the power button, it require AC to boot up.
Feedback: Yes, this issue repeat randomly, that End user could not know when the devices is fully shutdown automatic. Therefore it's an random shutdown issue, so far we heard from different users on their device experience. Each of us is different but yet still share the same bug issue.
So far we can see the following review:
1) Fully charge more then 8hours (auto shutdown)
2) battery left 30%~70% (auto shutdown)
3) fully charge as per device display (Auto shutdown)
4) End user press sleep mode + Battery fully charge, no background program running (Auto shutdown unknowingly)
Beside all this, the main factor to report was after it's auto shutdown, the tab7 need the AC power to power up again, else by normal power ON, nothing will execute.
Last but not to miss out, was the touchscreen issue on all side, as it will randomly output alpha or numeric that we did not press (e.g we want 1,2,3 but output shows 0,P,O,7) it's like out of sync on user finger touch.
This touchscreen issue happen in:
Typing in Email, Browser, Games login
Home screen and inside apps screen
*Inside "Setting" also will have this issue.
Overall: it's happen randomly at all areas of the 7" screen itself.
**For the firmware ACR receive, how would End user get this update ? Via AC Ryan forum? or ?? And Jelly bean is coming out soon, can this Tab 7 been upgraded to Jelly bean?
Pls advice.
