AC Ryan very 1st Android Tablet
AC-Ryan
Suspended
Hi,
What about the screen issue (post ##342)? Is it a manufacture defect?
How should we proceed? I have just received the item today and have yet to
register for the warranty. Are we entitle for a 1 to 1 exchange?
Yes you are, please see our official answer to your inquiry in our official forum thread.
impeller
I got my set last nite (collected from post office) and battery was totally flat. I need to plug into AC to charge.
During charging, I played around and did not encounter any auto shutdown. Will go home to try again tonite when it is fully charged.
I think after charging a several times, it seems that the auto shutdown doesn't occur anymore. Anyone still experiencing the same issue after a few days?
devilmaniac
where u guyz bought ?? wanan get it for my niece... is it good ? touch sensitive enuff??
csc12345678
Lithium batteries should not go flat. Discharging li batteries till zero will shorten the lifespan. :eek:
AC-Ryan
Suspended
Please see answers below.
Can anybody use their bluetooth, i cant on mine, tablet doesnt allow me to?
Bluetooth suport is currently not yet enabled on the existing firmware, but we will have it definitely in our future and hopefully on the next firmware release. Please note that you still need to use a BT adapter in using this feature
Can anybody use their flash drive to connect to the USB port, i have tried several thumb dive and it doesnt read.
We confirm that it can read a USB thumb drive and even a portable Hdd. What type of file system you have on your drive? You can also do a disk check on your drive as sometimes it will prevent to be detected when it do have an error.
Can anyone use their 3G dongle to connect to the internet. I plug mine to the USB port but cant search for the required network indicated in the manual.
Quote from my colleague under ACRyan Forum: If it is a Wi-Fi dongle there is no need to do so as the Tab already comes with a built in Wireless antenna that you can use to connect to your wireless network. If it is a USB modem, normally it will do auto connection after enabling it under settings. You can try to check it under the Tab settings ->Data Usage and turn on Mobile data.
Please note that not all USB modem will be supported. We will have a list of supported model soon and post it here.
Bubblebum
i tried using m1 dongle E1820 but it doesnt work. mobile data is set to on. Could it be M1 dongle cant be used on this set?
Bubblebum
i have found that the tablet discharges at a fast rate although i just leave it one side doing nothing. about 2minutes 18 seconds for 1% drop. which i think will last 4 hours... but that is if i am doing nothing on the tablet.
Bubblebum
another thing to highlight is that at the corner near the micro sd card your hand will feel warm when you touch the back. Can other users confirm is it the same for all or is it just me>>
csc12345678
Did you have the auto-shutdown problem before ?
torhar
Let them fix all the bugs first
Before you buy anything from Ac Ryan.
They advertised alot of nice things regarding their Veolo product, but since january 2012 they have not fixed a single bug. They claim that they are testing android 4.0 so they can't spend any time fixing existing bugs.
Veolo was to say the least an alpha product, and reading in this and in the Ac Ryan forum they are repeating the story letting the customers take the fall when the product fails.
kennyboy
Interesting. You created an account just to post that?
19dino
We are currently using a 3G modem from the two service provider and it works :)
Can at least say what type of dongle it is supported?
List of tested dongle.
The makers, type?
Want more info before deciding to buy.
icy1118
Would appreciate if somebody can share their experience in getting suitable casing/cover for this device, I need protection to this device!
zzedg3
Understand from ACR that the casing that are selling outside does not fix to this tab7. Currently ACR is pending for creating their own casing/cover for this tab7.
in the mean while, suggestion is too buy those bigger pouch tt can fit tis 7" tab7 inside.
AC-Ryan
Suspended
The makers, type?
We already have it, we are just waiting for it to be uploaded on our official website and will provide here the link.
*Update:
Below is the link where you can check all the available USB modem supported.
http://www.acryan.com/forums/viewtopic.php?f=190&t=19607
