Xperia Arco S
yuehernkang
When is the Xperia Arco S coming out?
REALLY CANNOT WAIT :mad::mad::mad:
Cant wait to sell my slow Xperia Arc and get the Xperia Arco S!!!!!!!!!!
Whos waiting for this phone too? Or are there better options out there
ashethen
i waiting also.
hopefully same price as xperia s. if not out by august then have to settle for XS
rssd21
Main advantage of acro s over xs are 16gb internal memory + memory card slot, bigger battery capacity (1900 vs 1700 mah) & water + dust resistant.
pker88
hahaha xs is what's hahaha
looks wise ya xs wins over Arco s
specs wise arco s
if can wait for the LT30 rumor xperia gx
with the body of arc then it should be the real arc replacement hahaha
with even more epic specs
ragnarok95
Senior Moderator
Senior Moderator
BUT ARCO S IS WATER PROOF LEH. HAHAHA WHAT IS XS LOLOLOL
Waterproof yes... wait till u start to use and everyday you remove that cover to plug in your usb and earphone then tell me is it still a good phone or not.
yuehernkang
Oh....... THEN MYBE I CHANGE MY MIND. WHEN COME OUT IN SINGAPOrE TEST FIRST SEE GUD ANOT DEN BUY
rssd21
Then frustration sets in and time to look for new phones. :D
ragnarok95
Senior Moderator
Senior Moderator
You don't need to use CAPS to reply... you know.....
Oinkize
Prevention is better than cure.
Water resistant and dust proof makes it an even better phone to use.
imagine bathing or under the rain still can talk on the phone...
shiok sia...
naxchua
Use bluetooth headset lor... then all your input jacks are safe... :)
ragnarok95
Senior Moderator
Senior Moderator
shiok sia...
Plus and minus points. If it serve you, then go for it because diff user diff needs.
How often do you talk on the phone under the rain?? :)
dreamz13
quite useful when u have a kid who likes to dunk your phone in water
