[Mac 101] Ask your questions here!
hyperpower
can someone recommend a good software for msn messenger? I'm using microsoft messenger for mac but it lacks many functions and can't allow multiple sign in.
desire777
considering to buy the mba 13 end month. Any bro can advise what accessories to get ? Sleeve or case ? palm and keyboard guard ?
And also where to buy the accessories cheaper ?
evolute8
2012 13" MBA i7/8GB/256GB
Are these speeds faster than the toshiba SSD?
Hendrix
my macbook charger suddenly is not working. i never bent the wire awkwardly or anything. In fact it still looks brand new, any idea if i can get it replaced? bought it at sapura sim nov 2011..
jupiter12
Hi all
Like to ask something about the menubar icons on your Mac OS X?
Anyone has alot of icons on the menubar such that some of it is not visible as there are limited space for it.
Is there any way or applications that can put a second menubar below the original menubar?
Regards
hyperpower
Hi all my friends on windows have problem sending files to me via msn. Usually it end up me not able to see and accept the file. I'm using microsoft messenger, I tried adium also have the same problem. Adium even worse, I can't even send out files.
any solutions or recommendation for a better software for this? Thanks
shawn_sboi
try aMSN :)
if can't then tell your friend email or dropbox :) it's 21st century already.
tamago_
Deluxe Member
the test is taking years. definitely slower than yours. Late-2011 MBP 17" i7 2.4 quad/8GB/256GB TS (SSD from mid-2010 MBP)
tamago_
Deluxe Member
oh yeah i did a quick check, mine is a SATA II SSD on a SATA III connection
bockscar
Finally got my Macbook Pro yesterday.
Do i need to register the warranty? Or is it automatic from the first time i boot up?
The reseller only told me to register the Applecare after 14 days. Not sure about the original 1 year warranty itself.
tamago_
Deluxe Member
1 year is standard, Applecare covers the additional 2 years.
bockscar
I see.
For the standard warranty do I need to register? (I know Applecare must)
Also, anyone knows why sometimes I see the battery life indicator on the left side of the macbook pro. But sometimes I dont.
When i plug in the magsafe i will see it light up but after awhile it disappears.
Im not really sure how it works in the first place so it may be functioning properly but i'm not aware.
shawn_sboi
I see.
simple.
check here https://selfsolve.apple.com/agreementWarrantyDynamic.do
put ur serial.
if not they will ask u to register :)
Revuelto
Guys, I am contemplating between the stock 4GB Ram and upgrading 8GB Ram on a 13" MBA. Mainly using for word/excel, presentation, surfing and entertainment while travelling.
Not sure 4GB Ram can last me 5 years for future OS upgrades or not.
shawn_sboi
13" 2011?
then upgading it to 8GB is worth it. Ram are cheap now.
zitseng
5 years is a long time. You'll eventually run out of RAM. The upgrade is a small price to pay for something you want to keep that long!
siron
Just curious, what display settings are you guys using?
I am using the scale (most space) since I am too used to my previous 17' mbp.
