Sep 2012 BTO
Searph
This is my 6-7th attempt, closest I got is within 150% of the available unit.
There's always next try. Ha ha. Good luck to you too!
6-7 attempt?? Is it that hard to get a good que num for first timer? I'm thinking of applying for Sept BTO and is first time applying it. My parent stay near. Will I have a good chance?
misspotato
is all about luck. jul i applied punggol 4 room, first timer, near parent and first time apply. number 9xx out of 754 :((((( summore i pray at so many temples, made wish at meteor showers. no luck!!!!!
kingf00l
To be honest, I am quite picky when applying, so most of the time I apply for the more popular ones, maybe that's why I never get good number.
this is the record
Jul 12, BM, 9++
May 12, KW, 11++ (% wise the closest)
Mar 12, SOBF, 200% more
Sept 11, SOBF close to 300%
July 11, Punggol 5 rooms, no number
Mar 11, SOBF 200%
can not remember the last time leh, no number also
I go see MP, go pray, go Thailand once, still like that. Ha ha, what to do?
I am just glad that my parents are not chasing me out. :s13::s13::s13:
kingf00l
Hope my records make you feel better. Ha ha.
Guyver
failed to get BTO ballot .. for July .. so perhaps i am trying for this. sigh.
misspotato
If we really want a selected bto from mature estate and 4-room, is it advisable to apply despite of high competition (lower chance of getting) or should go for 3-room instead (higher chance of getting)? Any suggestions?
UpperCut
I was in a same dilemma as yours.
My advice is to discuss it thoroughly with your spouse. If you miss this BTO the next one is in 2 months time. However, if you choose a 3room and it doesn't suit your needs, you will end up regretting for at least 5 years during the MOP
lampano
its all about luck actually.
New 3rooms are really small, think wisely.
You are likely to be staying for a very long period of time.
Affordability and family space is a major concern.
skjh7`
Strongly agree with lampano. Need to think many many time. cos this is not buying veg in the market.
Searph
I heard from my friend that if we were to get a 5rm BTO..we will not be able to get a 4rm flag the 2nd time..is it true???
Chevalier
gonna give my first attempt to the amk bto as well, 4rm. missed the july one. hope i can make it
3G SAINT
this is the record
Jul 12, BM, 9++
Mar 11, SOBF 200%
:)Are you 1st timer apply near your parent:s8:
Most 1st timer try at least 3-4 times will get flat for mature estate:D
I think you do not have luck:)
3G SAINT
:)You should able to get after 3 attempt:)Need to queue up..:s12:
