(Storage) SSD Discussion Thread
human_shieldz
i couldnt even install win7 on the ssd ;(
Wait Wait, after i installed then i change to IDE from AHCI and during booting its always stuck at the Windows logo then reboot again and again, so i switched back to AHCI.
Was asking, you mean even in BIOS it doesn't detect?
kreja
i just plugged in my ssd. couldnt install win 7 at all.. dunno why. i tot it should work just like normal hdd. :(
human_shieldz
Thing is that it doesn't. Well, mine was fine during installation. It was during usage that it's not fine :mad:
Anyway, i doubt i'll get another SSD yet until its dirt cheap.
dawntime
Dirt cheap, maybe until something better than SSD comes out :s13::s13::s13:
kreja
whats the difference between ide or ahci?
I couldnt get the ssd to detect in ahci mode, so im installing in ide.
managed to get the installation done.
but usuage wise havent try
jovially
Need some advise.
I will need to upgrade my SSD from 120G to 180G.
Should I connect both the SSD when installing win 7? Will it allow me to select the correct SSD for the OS?
How to reformat my 120Gb SSD (OS drive) so that I can use it for data drive? Thanks.
Is there a command like FDisk or format use in normal hdd can can be use for SSD?
kreja
Followed the below guide:
Sean's Windows 7 Install & Optimization Guide for SSDs & HDDs
The guide said to just installed the latest Intel RST drivers.
http://downloadcenter.intel.com/Sea...2+Intel+Rapid+Storage+Technology+(Intel+RST)"
I picked AHCI: Intel® Rapid Storage Technology Driver for Intel Desktop Boards 11.2.0.1006. There are RAID, RSTe version. Are they the same?
Finally managed to get win in AHCI mode. mobo is GA-EP45-UD3R. Noticed that AHCI mode bios take longer to load, making boot up time as slow as IDE mode. Is that normal? This mobo don't have SATA3 either. Is it still worth it to stick to AHCI?
Thanks for all the tips.
xonix
Need some advise.
Your 120GB also installed with win 7?
If yes, just clone 120gb to 180gb.
After cloning, boot using 180gb and re-format 120gb using Win 7.
kreja
hi,
i'm having problems with my ssd installation again after trying to backup an image of my ssd drive via clonezilla and restoring the image. AHCI mode fail to boot again, I'm force to set to IDE to enter windows.
any idea where did i go wrong? I would like to create a clean image of my win7 installation so that I can revert to a clean version of my os everytime something screws up.
thanks.
George Soros
i install acronis true image
half way installation it ask me to restart
after restart cant enter window too..ask me repair or enter as normal
both cant
thrn i reinstall fresh window 7
kreja
i re-ran win installer, delete my disk partition in IDE mode. reclone using clonezilla. its working again. not sure if I've done this correctly...
RSKeisuke
Say if i fresh install my os on a newly bought ssd, am i able to set my existing system hdd as secondary and assess my data?
i.e. Copy data over to ssd temporarily, format the hdd, then copy the data from ssd back to the hdd
zwchia
If you are gonna do a fresh install, just install the os into your ssd using the install cd/dvd and do nothing to your current hdd. It's like installing a new os into a new hdd. Then your current hdd can be used as a secondary drive and you can do whatever you want to it later. No need to transfer stuff here and there, unless of course you are talking about cloning and not fresh install.....
RSKeisuke
reason why i want to format the existing hdd is to remove the OS and software, to make the HDD purely a data hdd
MiImbEn
installed m4 and with my hdd in a optical drive caddy..
so far so good..
ssd as main drive with a hdd on a laptop system becomes damn fast now...
