sirbrian
- Jun 4, 2004
1. The sheet is scratch-resistant & shatter-proof. It is on the screen by factory settings.
2. It is removable.
3. The screen & sheet is only scratch resistant, as well as any other sc on the market.
There is no such thing as a shatter proof sheet being scratch resistant, correct me if I am wrong. The shatterproof sheet acts like those on the car windscreen or even on the airplane cockpit windows. It is just a "soft" laminate to prevent the glass from complete shattering and thus endangering the users. So if you do happen to drop and cack the mineral glass, you will not cut your fingers if you accidentally swipe past the broken portion.
This thin layer of sheets are in no means scratch proof. Sony may claim it to be hard coated sheets but they are still prone to scratched due to use and wear. Only the Gorilla glasses in my experiences are much much more scratch resistant.
I will never recommend to remove the factory fitted shatter proof sheet as it is there to serve its purpose. If we want more scratch protection, it is better to add another layer of SP (like those of good quality ones from 3M or SPIGEN SGP etc).
