sliver0503
just to share one of my wip
painted the strike to rogue color scheme
more wip can be found here
freshmeat81
Where to customise Acrylic Display Case which
is cheap and good?
China square central has a bazaar at the ground floor that sells display cases that is suitable for most mastergrades. About $10 I think.
If u need large sizes u can approach hardware shops for cut acrylic pieces. Just pass them your measurements and ask for a quote. Should be quite cheap in general if it's
2mm thickness.
gentoro
So exp? I get my chinese Hobby jap at some newstand at only $6 each monthly! :s13:
$25 for it? KNS! If buy in JB malaysia comic store, only RM10-12 each, laggi cheaper!
Of cos these cheap cheap version doesnt come with the freebies kit or add-on which I think is useless! Alot of these freedies will be be on sales very quick in few months later and cheap too!
CSC at level 2 also got sell Chinese version Hobby Jap. At $13-15 I think which I think its a ripped off!
I stopped buying for a couple of months liao, magazine pilling up and no more space.
NotMyStyle
2mm thickness.
I asked and got quoted $130+ for a 88cm x 21.5cm x 26cm. Expensive anot? :(
bukitview
Am planning a trip to Toyko this December, any models that are exclusive to jaoan or Gundam Toyko Front that i should look out for or consider?
Am thinking of getting Sinanju Titanium, cos Singapore ones are expensive
Any advice?
guiltysky
hmm, some question about waterslide decals.
do u use guys both mr mark setter and mr mark softer when applying decals?
osirisx
hobby point has some acrylic cases for MGs and stuff...iirc
average price around $30, bring $50 should be more than enough
ongkh2000
Any advice?
if im not wrong the only jap limited kits are those at GFT...
generally prices of gunpla in japan would be better than in SG. so shouldnt be any problem.
