(Storage) SSD Discussion Thread
haodede
Suspended
Does anyone experience freezing issue with M4?
It occur again just now when I was surfing the web normally with my music turned on. You could hear the music slowed down drastically and nothing is responding.
So I force shut down my laptop, in order to re-detect the my M4 I have to go into BIOS menu.
I have already re-install my OS (Windows 7).
IIRC, my previous SSD (G.Skill Phoenix Pro) also have this issue.
Any solution? :(
hlots123
Any solution? :(
hmm m4 & g.skill ssd have diff controllers so problem not controller-specific. try setting "turn off hard disk after" to "never" to see if its sleep/power related...
HELP! New Intel X25-M SSD Freezing/Stuttering
Jhyun
hlots123
Hmm... doesn't works. My laptop just froze again.
u may want to look into registry fixes similar to this one, How to fix your SSD freezing issue (we hope!) - The Corsair Support Forums
i not familiar with those reg fixes, as i try to avoid any ssd that potentially require it. so u shud ask/read around for more current instructions.
btw did freeze problem occur right after u swap hdd for ssd? quite rare it seems, ur freeze problem is total unrecoverable freeze + change other ssd still happens. any chance not ssd-related?
human_shieldz
Any solution? :(
My Intel SSD has this issue. Do you see the HDD solid in colour?? After some troubleshooting for mine, i found out this.
1. The moment i'm connected to Internet and there are Internet activity only it freeze but i think actually not freeze, just that the SSD is being access aggressively i think so i can't do **** about it. Try disable your Internet connection and see if helps.
2. I figure it's silly not to have Internet then work, so i follow the guide someone put it out on how to optimize your SSD. I followed a few, not all but i think the one that eventually solved the problem is disable Indexing.
Now my SSD work normal le but like no speed advantage :s13: And it still says i'm using RAID when i'm not. Bah :eek:
Not sure if you are having the same issue as me but try try.
haodede
Suspended
Hmm... I thought of it too. It only occur when I am using SSD.
I just updated some of my driver via the manufacturer website.
I have disabled indexing.
Can you further clarify your RAID part ? I don't really understand ? :s11:
SPEED
To haodede
are you using Macbook?
Macbook and M4 with 000F FW has like got hanging issues
pker88
Hmmm looks like Intel 520 120GB have dropped to a really reasonable level now, is it worth to buy ?
in the budget of 150-170s, considering the Crucial m4 128GB, Samsung 830 128GB and Intel 520 120GB now.
will be on a SATA2 board so lol.........
Crucial M 4 128 GB SSD. best value ?
I plan to hoot to use as spare hdd like gaming on. it
but os still on my wd black
planing it for desktop
xonix
Huh? Usually it's the other way round for most people.
Not enough space, just move your media to secondary HDD
I run my M4 256gb (OS/PROGRAMS/GAMES) with 500gb (BT)+320gb (STORAGE)
davidquah
I run my M4 256gb (OS/PROGRAMS) with 500gb (BT)+320gb (STORAGE)
same for me.
m4 128gb has OS and programs.
the games on normal hdd.
pker88
oh nope I mean I put game on ssd
but I still remain my os on main drive the c drive
while ssd on d drive example
just too lazy to redo c drive with os hahaha
hlots123
curious, i ran the cmd "fsutil fsinfo ntfsinfo c:" on my ssd drive and the output is--
Bytes Per Sector : 512
Bytes Per Physical Sector : 512
Bytes Per Cluster : 4096
kinda surprised, i thought at least "Bytes Per Physical Sector" should be 4096 for ssd? instead it looks like mine is 512-byte native (like older non-advance format hdd), if so how come proper alignment during os install is required?
Information about Microsoft support policy for large-sector drives in Windows
any insight abt this? thanks... :s11::)
