iRobot Scooba experience
wongkc
Q1. Whats the difference between scooba 380,385 and 390?
A1. 385 = Europe model (S'pore agent selling this due to voltage similarity)
380 & 390 = USA model (voltage of charger is USA 120V, requires Voltage Convertor or charger modification)
380: Version 7 software (found on S/N) if made after Sep 2011, Version 7 gives 30% longer battery runtime by virtue of power tweak
Version 7 Scooba 380 also have the orange colour code for all the things to rinse after use, the Water Tank handle got slightly different design (dunno if it helps prevent handle breakage, a common thing)
390: Version 7 software, orange colour code, whole robot change colour to Dark Grey, iRobot excluded 3 accessories found in Scooba 380: 2nd virtual wall, External Battery cradle & Waterproof resting mat
385: probably version 6 software, just like Scooba 390, doesn't come with 3 accessories found in Scooba 380: 2nd virtual wall, External Battery cradle & Waterproof resting mat
Although I'm still using my faithful old version 6 Scooba 380, my customers who're using Version 7 Scooba 380 reported that Scooba clocked ~130 mins total runtime, very inline with iRobot's claim of 30% increase.
I need to clarify though, to accurately compare, we need a standard environment (ie. floor friction, amount of furniture, amount of water filled).
Meaning, if u test in ur home, results may differ slightly vs testing in my home. Cos a slippery floor makes Scooba do the "Turbo Boost" to free itself, lotsa furniture means constant changing of direction & loss of momentum, water filled is essentially weight that Scooba needs to carry.
Since day 1, I fill less water for small room, cos for Scooba to piggyback extra water which won't be used until next room, is a waste of stored battery power.
Q2. My place is homogeneous tiles in the living room and parquet in the bedrooms... total area around 1200ft.
A2. Roomba & Scooba will work fine on homogeneous tiles & parquet (assuming has Polyurethane coating).
1200 sq ft is big, but in reality, that includes many areas that u won't let the robots go anyway.
Q3. Lazy to check out the features...
A3. Welcome to Lazy Club, come'on... stop kidding urself, all robot users are lazy.
Q4. but i want something that i can program to clean at a specific time...
A4. Only Roomba can be programmed for auto-start
Q5. and if i get the combo, do i let both run at the same time or which one do i start first and in what interval?
A5. Just don't let Roomba & Scooba cross territory, Roomba tires will leave tire tracks on moist floor & u won't want the brushes to sweep water cos it's messy.
Always Roomba first (ie. sweep), then Scooba (mop). Logically, u won't mop first then sweep right? :D
Thanks for the detailed explaination. So i have to get scooba 385 rather than 380 or 390 in order not to mess around with the voltage or adapter or converter?
uno_bliss
U can get Scooba 380 or 390 and look for me for charger voltage conversion. I sell Scooba 380 anyway, already ready for local voltage.
Getting Scooba 385? I would say 90% chance it's still Version 6 software.
I've been selling iRobot products full-time on eBay since Aug 2008.
For local ready for delivery items & local round the clock tech support from me, pls visit my eBay iRobot store:*uno bliss | eBay
Queries pls email me unobliss@yahoo.com
Xiaodingdang@Work
Cleaning the Scooba after each use
Hello
Sorry I have another question. I went through about 200 pages and don't have time to continue....:s22:
How long does it usually take to clean the Scooba 380 or 390 after each use? I read some Amazon reviews that its a pain, yet another said it takes about 2 mins :s11:. Ease of use and maintenance is important to us, as we don't have much time on weekday nights and there are other chores.
Thank you:)
uno_bliss
Hello
Thank you:)
Rinse (1) small rubber tube (~10 cm with DIA 2 cm), (2) small mesh filter which trapped dust, hair, crumbs, (3) scrubbing brush & brush casing, u can anyhow rinse or rub with fingers, depends how on u are, (4) water tank, fill dirty compartment & give good shake, repeat if got mood, (5) lastly, lovingly wipe dry Scooba.
I spend ~5 mins, some people never maintain at all & parts get very dirty cos stains dry up.
All in all, compared to rinsing a rag, or Pail & Mop, Scooba maintenance is much easier. But when people buy robot, they all think they are the Jetsons & Rosie will do everything.
Xiaodingdang@Work
I see, 5mins, that's not bad at all, even 10mins is ok. Thanks much Uno. One of the reviews I read complained that it took nearly 20mins to clean after each use which alarmed me - we really don't have that kind of leisure on weekdays. There is toddler to feed and bathe, dog to walk and feed and clean up after, dishes and pots to wash, next day's meal to be prepared, toddler's supper, putting to bed, laundry and ironing on certain days, grown-up's dinner and washing up - all within a span a two hours.
uno_bliss
U really need Rosie lor...
Rosie, the Maid from the Jetsons
Xiaodingdang@Work
ahem... we are the Rosie, and calling for help! =:p its not quite that bad, if the floor mopping or washing can go auto, it's quite a relief.
uno_bliss
I'm a lover of Power Tools, ie. things powered by battery or wall socket. I'm also quite a neatness freak (for lack of better word).
I got Rainbow vacuum (monstrous water-filtration pocket burner), about 5 handheld vacuum (Black & Decker 12v Flex, Shimono 7.2v, Philips 900w handheld, and few other crap), Advante Stingray steam mop, H2O X5 steam mop, Spin Mop, Swivel Sweeper, no brand hand push sweeper sold outside OG, Black & Decker 6v scrubber (for toilet tiles).
All these home cleaning appliances, some are white elephant (ie. use less than 5 times over 3 yrs), some I use when next best alternative is manual labour. So yah, I too could use a Rosie.
Vachel Chan
Hello
Thank you:)
Hi, Maintenance is pretty fuse free as what uno has described. For a better understanding, could always arrange for a demonstration of the Scooba 380 ($688) or 390 ($788) at your preferred time and location. Seeing how it works real time on your flooring and how to maintain it sure beats reading countless pages of the forum and going through various videos.
If you are looking are a combo, can always consider the New iRobot Roomba 650 ($599), pretty good value model. :)
For videos and specifications of a range of Robotic Cleaners, Do checkout Autovacstore.com
If you are
Xiaodingdang@Work
That's a lot of machines :s31: Almost like a museum of household tools liao. Neat-freak + cache of machinese + manual labout, Josie will be very busy. I see in the pictures that Josie can look stressed too :s13:
I don't mind vacuuming and mopping manually, sometimes, I downright enjoy it. Its just that these days, there's not enough to go around. The machine I really dream of, is one that can wash bathroom floor, than go vertical and clean the bathroom tiles, then the ceiling; in whichever order :s12:
Xiaodingdang@Work
If you are
;) i have time to surf around la, not buying til next year. i wanna narrow my selection first, instead of asking anyone to come over, and then finding that my selection was entirely unsuitable because i'd overlooked some factors. i'd feel like crap to ask for demo on what turns out to be a poorly-made choice on my part.:eek:
eh, i am already going to bed and waking up thinking of the Scooba, donch tempt me with a Roomba...:s13: can't afford two robots in a shot.
tekster
;) i have to surf around la, not buying til next year. i wanna narrow my selection first, instead of asking anyone to come over, and then finding that my selection was entirely unsuitable because i'd overlooked some factors. i'd feel like crap to ask for demo on what turns out to be a poorly-made choice on my part.:eek:
Bro, pls get both roomba & scooba.
Roomba runs while u are away. Then u come back and run the scooba.
bluefrog
roomba 770 US version
hello,
can the experts here kindly help me.?
i am currentky using local / uk version of roomba 580,
now in houston, saw 770 on sale so i bought it.
salesman claimed its dual voltage but on the charger it says
input120 vac, 60hz
input power 33w
output power 22.5 vdc bla bla
this is not dual voltage right?
when i get back to sg, can i simply use my new 770 with my current 580 charger?
if not, what should i do?
thanks!!
uno_bliss
hello,
can the experts kindky help me.?
i am currentky using local / uk version of roomba 550,
input120 vac, 60hz
input power 33w
when i get back to sg, can i simply use my new 770 with my current 550 charger?
thanks!!
Yah, the chargers are same & interchangeable. U can pass me the 120v charger for conversion.
Just PM or email me unobliss@yahoo.com
Jubooo
hello,
input120 vac, 60hz
input power 33w
thanks!!
The worldwide dual voltage should read fromm 100v-240v and the model is 17063. US 110v charger's model is 17062 and is a single piece as in from the wall socket to the plug is a single piece. The worldwide charger is 2 pieces, the wall socket can be detached from the charger.
I can also help to modify the 770's charger to worldwide voltage with a 3 pin plug that can plug directly to Singapore's powerpoint. Feel free to contact me at 81254240 should you require my service.
