StarHub MaxInfinity Fiber Optic - Experience
xiaode1987
Hi, any guy know if i get a ASUS RT-N66U, the connection issit same as
1) ONT->N66U
2) ONT->d-link dvg n5402sp->N66U
Which is better? or same?
Gribber
1) ONT->N66U
imo since I have done both config before.
same.
just that more footprint and power consumption lo. all boils down to what you need
nightkiller
hi guys,
today Starhub just came to my house to install Maxinfinity Fibre 100mpbs, on direct connection i was able to get 90+mbps on my laptop, however, when change to wireless i could only get 12mbps only. May I know is there any problem with the router, DVG-N5402SP?? thanks for any input
Gribber
hi guys,
the only thing that I can kknow from the above paragraph is:
1. wireless slow
2. router model
how to have input?
pker88
hi guys,
get a. new router bro
wired usually give the best speed. but wireless is. subjective on equipment and also house layout and. others interface
nightkiller
oh sorry for missing some infos,
My laptop is just less then 1.5meters away from the router with no obstruction at all. Actually for the wireless configuration there isn't much to change right?
Gribber
still missing with plenty of info. I will kickstart.
1. wireless router config is?
2. adapter currently connection at 300Mbps?
3. wpa2-aes only or?
4. tested with another device?
5. channel is what? alot of interference with your selected channel?
and etc. you dont expect people to help you by guessing mah
nightkiller
wow..didnt know miss out so much..i will go check more about everything first..thanks alot for ur help!
sillyb0y
Hey Anyone can help?
I've the DVG-N5402SP router and my desktop use wireless adapter connected to the router but the signal strength very low, transfer speed very slow and sometime would d/c..
should i get the below either 1 router so will make the wireless connection and signal strong?
RT-AC66U Dark Knight Rises
RT-N56U Wireless-N Dual-Band Router
any diff?
Gribber
any diff?
yes
AC66U key point is.. it supports ac lo.
N56U key point is... its cheaper than AC66U and it only supports 2.4GHz and 5GHz
if you keep getting dc, and the range is unobstructed or not too far off from the DVG-N5402SP, my advise is - get starhub to replace a unit for u
sillyb0y
yes
The range quite far and obstructed by wall?
For wireless wise, which one will be better for improve the signal and speed?
Poker
Hey recently my aunt house just use sh fiber but I notice the Internet is really slow
She lives in by panjang area
Using wifi
Speed less then 30mpbs
randomforumer
the starhub huawei wifi i think not good at all leh !!!
if use wire ,
the max speed will be achieve.
but if use wireless right.
the speed is very in-consistent .
think the huawei thingy not good for wireless at all..
stone11
Unable to connect to Xbox Live via Starhub fiber broadband, wired and wireless... Any solutions??
chercm
if use wire ,
then tell them you want to use your own router then provided if you do not need the voice service
Gribber
if use wire ,
bridge with another router if you are on VoIP
mingean
huawei router bad?
sounds like issues with huawei router.
do they issue other routers? i.e. without us having to pay extra?
apart from that, is speed cap to international sites still enforced? :s11:
thinking of maxfinity, just for hubclub discounts. but wanna know if its worth it.
btw, cable used to be shared bandwidth with the block - fiber also shared?
thanks in advance
Gribber
thanks in advance
yes, dlink - no need to pay extra
yes
worth in value bt not in service. you choice
everything in shared even adsl. you are in a wrong era thinking that services is yours truly.
