GALAXY NOTE II ACCESSORIES
Akai Ryu
NICE! u got the mount too!! haha.
it was delayed for toooo freaking long..
haiz.. still awaiting for my set (phone) :(
yup...ordered out of novelty sake :D
U using for photography/videography purpose?
sukmadik
Song bros SLS variety of Zenus casings ranging from 59.90 to 89.90. Lost for words..
unintended
Will privacy screen affect the functionality of the S-pen?
Eyeing on a privacy screen, but havent seen one around yet.
xhoyasx
if u afraid ppl dunnou using note 2....silver trimming ish.......
where to get this?
sukmadik
found these cheap casing at SLS level 2 shop called IT World. They even let you open the box and test if your phone can fit snugly without any problem.
got myself the transparent silicon casing with stand for only 12.90. good enough for a temp one until good ones are available. really eyeing otterbox. :s13:
doomgaze86
Does anyone know if the S3 MHL adaptor works with the Note II? Also, is there any way to check if the Samsung MHL adaptors out there are authentic?
sukmadik
Got full transparent without that thing
don't have leh.. i also looking for one but this was the next best thing.. the rest of the shops at every level cheapest is 25.90 for some kind of metal casing without bezel protection.
lorettatay
go obostore.com to take a look. i ordered a few diff brands of slim and transparent cases for my note 2 to interchange. the prices very cheap. now waiting for them to ship.
GamerZ
anybody know if ComCenter sells N2 covers? I got $20 voucher I need to use by year end!
Vulpix
Moderator
Moderator
Comcenter actually carries the biggest range of N2 accessories among the other sinktel stores.
hammerhammer
I bought one similar but somehow the part Where u put in the usb cable, it is not well cut and can't fit in the cable so I had to remove case to charge. Is this OK case well cut to fit in the usb cable?
I recalled u posted the link on Where to purchase But I can't find it, care to share again? Thks.
Use nail clipper to trim the hole then can fit liao...:D
