iPhone 5 Accessories Showroom (NO SELLING)
keigo22
Which one did you installed? How is it? Seems like the Sector 5 is about 1mm higher from the surface of the screen. The glass about 2-3mm thick?
hmm after go google.. I think for iphone5, don't think any metal bumper will cause any signal lost issue now unless the back panel is cover by metal. To be correct the top and bottom back panel is cover by metal.
"the iPhone 5’s back panel features a cell antenna on the top and bottom of the device, surrounded by a thin strip of glass that allows Wi-Fi, GPS, Bluetooth and other signals to “peek” through. These antennas are so far apart that unless you have freaklish long hands, it’s impossible to “bridge” them with your grip. So long Antennagate."
Read more at Why Apple Is Killing Off The Bumper, And Why You Won’t Need A Case For Your iPhone 5 | Cult of Mac
defelio
I installed the HugU Glexible one , after reading deep3lue's review i decide to get it. It is bout maybe 0.05mm higher than surface screen. So far the glass is like any screen protector just it is made of glass so maybe it is stronger can take damage impact if iPhone drop face down, easy to clean if there is finger print or oil after talking on phone and ya the glass is about 3mm thick . :s12:
Sweet! Dun mind sharing where you bought it from?
indraven84
[/IMG]
[/IMG]
HugU Glexible glass and Sector 5
derkaiser94
Flimsy or fragile .. won't know till tonite... :(
Maybe owner of the sector 5 can comment now?
I don't think it feels flimsy but it certainly looks that way compared to the vapor pro due to how thin and light weight it is.
deep3lue
Correction, 0.2mm. Glass Guard is 0.3mm.
Sorry, have been playing with too many glass screen protector recently. :s13:
ragnarok95
Senior Moderator
Senior Moderator
Ok. Fitted in the Tones. Like it. ALOT. But not without complaints.
This TONE is def one of the BEST fitting bumper around. It fits the iphone tightly and it is very light weight, much lighter than my SABIO. This make my iphone very very light. I like. The feel is there and the 2 material combination makes it out-standing.
However, build quality...i feel, it's still not there. Can be better, esp the round edges. After fitting in the phone, it don't have that "professional" and "classy" look anymore.
And i wish they could have chosen a darker grey instead.
Overall, i will give this a 4/5 stars bumper. It's reasonably priced and the you still get tons of accessories.
deep3lue
Told you guys it was tight right.. :s13:
