tanyieern
Hi,
Just top coated my model today morning and just checked, there were some white patchy stuff all over. Did i do something wrong?
Thanks in advance.
Bryson
is there a button at the bottom of the tap?? press it to equalize the pressure inside and outside, then try to unscrew. Hope it helps
Finally took it out and give it a good clean. :s12:
BTW, was wondering how to remove dried lacquer in the airbrush if it happens? Soak it in thinner and brush it off?
Thanks! :s8:
Bryson
Hi,
Thanks in advance.
I assume you flat coat it? It might be caused by the weather and humidity or maybe because you didn't give it enough time to cure. I would at least wait at least 30 mins before spraying 2nd coat to play safe. :s13:
tanyieern
I only sprayed 1 coat... Probably is the weather. Raining frequently the past few days. Is there any way to remediate this?
osirisx
must be spraycan, only spray it on a dry hot day.....
use hobby thinner wipe off
Bryson
Any hobby thinner will do?
I tried using lighter fluid, white stuff reappears after the fluid evaporates...
Iirc, those clear coat sprays are lacquer. So you can only use hobby thinner, e.g. Gaia T07, lacquer thinner, to clean it off..
Correct me if I'm wrong. :)
wolvie77
Hi! all. i'm currently painting a endless waltz wing zero HG. trying to hand paint its neck or collar part bluec& white. having difficulty painting in between the narrow gaps between the collar part & the part where u attach the head. any ideas??
aucheukyan
toothpicks or 00 brushes??
noForm
hlj.com is on offer...
PG stike freedom is half priced...
1/100 ng 00 raiser clear version so cheap...
castafarian
Anyone know if there will be any Gundam related things happening in AFA2012?
depends on what u looking for, they did sell some figures last year and some exhibits were on display (just like what u would see in Gundam Expo, but on smaller scale?)
kentcalvin
Just wondering if there will be any exclusive kits or great discounts :D
