(Storage) SSD Discussion Thread
Hermanchan77
Hi guys, i just bought a full hd Y580 today. Haven yet to trst run. V. Excited about it. Guys, must i change myHDD to SSD to run the laptop faster?? Much much does a SSD cost?? Any cooling pad to recommend??
enenyi
To make the Y580 run faster, yes, coz the HDD seems to be the bottleneck in speed wise. Typical SSDs currently range from $120 to $190 for 120GB/128GB and $255 to $345 for 240GB/256GB SSDs. I would advise getting Crucial M4 256GB SSD at $270 (PCThemes). Else u can also use the HDD, just add a 128GB/256GB msata SSD in the msata slot (beside the HDD slot) and boot from the msata SSD.
MiNdFrEak
Hi guys, I'll be getting my Acer Aspire One 725 2moro. Already got the Kingston 4GB to replace the stock 2GB. I am looking to get the Crucial M4 64GB or the Samsung 830 128gb both with transfer kit.
Anyone knows if sls has the one with the laptop transfer kit and the price range? I'd appreciate it if anyone could provide me links to upgrade the AO725.
Any other opinions also appreciated. Thanks. :)
cnt
Hi all SSD Guru, recently bought a Intel 520 240GB SSD. Can someone advice is this benchmark ok? Or could it go any faster?
Thanks for advice!
u cannot link pic from ur hdd. go photobucket create a a/c :s42:
vapor77
adrianlee
OWC Mercury Electra 3G MAX 960GB Review: 1TB of NAND in 2.5" Form Factor
AnandTech - OWC Mercury Electra 3G MAX 960GB Review: 1TB of NAND in 2.5" Form Factor
Corsair Neutron GTX 240GB SSD Review
Corsair Neutron GTX 240GB SSD Review - eTeknix
Corsair Neutron 240GB SSD Review
Corsair Neutron 240GB SSD Review by VR-Zone.com
Corsair Neutron 120GB SSD Review
PNY XLR8 PRO 240GB SSD Review
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=970&Itemid=60
leonaheidern
I'm a noob at this ssd thing.
Is this fast or slow for a Crucial M4 256GB SSD. or ok. Bought it cause my WD 1tb green kept hanging while playing diablo3 until I cannot tahan already.
Best part is I did all the hdd scans on the 1tb WD Green and cannot find anything wrong with it.
Oh and I think I plugged it into the white port of this motherboard Asus P8H67-M PRO which should mean Its Sata 6 right? cause theres supposed to be only 2 sata 6 ports. and 4 sata 3 ports.
i1magic
This is for my Samsung 830 128GB on SATA2 port.
This is Samsung 830 128GB SSD on SATA3
I did both SATA2 and SATA3 test above ... you can do a comparison.
BossQ
Hmm... If I installed VMware on mSATA drive but load VM images from mechanical hdd, will there be improvement of the VM performance?
adrianlee
wc1985
Hi guys i recently received my mushkins chronus dexluxe 240gb ssd and i did a benchmark test on my sata 2 motherboard may i know if this result it normal?
so far i only feel shutdown and startup speed is improved havent install any games to try yet
one more question, how do we know whether our sata cables are sata 2 or sata 1
eyz
wonder if I should post here or the Win8 sub forum.
basically I want to have a clean install of Win8 on my Crucial M4 128G ssd.
the sdd is now a clone of my then Win7, which in my opinion, the performance is more or less the same as my then harddisk Win7. I don't see any significant decrease in bootup time. This could probably due to the bad cloning procedure.
I had previously meddled with my BIOs in hope to tweak the performance, however it didn't help much either.
I am now thinking of giving my SSD a clean install of Win8 and would like to know whether should I do anything to my BIOs, in order to get the most optimal performance? Or procedures to prepare my SSD and PC to install the new OS.
Thanks.
PS: I am using a Gigabyte MB, will furnish the exact model when I'm home, if it is necessary.
c1steady
Hi
I just bought crucial M4 128GB SSD. After installation, the start up is super fast. But shutting down also super slow. Sometime 5min to shut down.
Anyone encounter this problem after switching from normal harddisk to SSD ?
wc1985
Hi
i think its problem with windows update
theoryjack
sata cables are standard, there is no difference btw sata 1, 2 and 3 cables (in terms of connectivity).
adrianlee
