Hi guys, I intend to change to a new phone early next month which is november. My shortlist are Xperia Acro S, Xperia ion and Optimus 4X. Any suggestion? Does the headphone flap on the Acro S easily spoilt or inconvenient in everyday use?
But the price is a point of consideration also leh, how much do you guys think the Xperia T/TX or V will cost once it hit the local markets?
screen shot press power button and volume down at the same time
tried, it doesn't work leh. tix is what i google but don't work. Or must I root?![]()
You must press and hold BOTH button DOWN SIMULTANEOUSLY and wait for the shutter sound before you let go.
hi guys, i know i might be digging this thread, but can someone tell me overall is this phone good?
i feel like changing a phone soon, and with a tight budget in hand, my only choices are samsung galaxy s2 and this sony xperia acro S.
cant decide between this 2 and some of my friends are saying sony phones are not too reliable wor. so how ar?
actually between this and Sony xperia S, which one better? and do ppl actually buy screen protector for this model?
thanks for any kind assistance
thanks for the reply. actually the reason why my friend say Sony is not reliable is because of the company's stability >_>
it sulks if i spend money to buy a phone, then within months the company go bankrupt or something
and, how bout the screen protector? how come like so little info bout screen protector over the internet?
No problem for sony, they will only downsize when times are bad. They will not close down. Go google sony and you know they are doing big businesses in many industries.
For sp, its usually hard to find in local. You have to rely on online stores or official retailers.
try ask dataflex they might have SP
plus they also offer custom cut SP
they are located at AMK hub and jurong jcube
I remember one user reported dataflex custom made sp is not good. Not sure about the jcube one though.
ya usually custom made is not as good as pre made
for specifc models
but if really need SP then got to look for alternative or online
or fly to jp
You can get the SP Amazon JP, which is where I got mine. You can search for Acro HD, which is jap version of Acro S.
Amazon.co.jp: Acro HD SP
Or you can just get a case (if you don't mind the extra hole) that comes with a free SP.![]()
