Thanks bold10
Having an appointment means I definatly have a chance to select a flat?
Thanks bold10
Thanks bold10
May i check under what circumstances consider a dropput?
If HDB give u selection date but u cant make it, will they forfeit the queue?
Haha am looking for possibilities to console myself I will get to select! hahaha
IC.
In that case there is still a possibility that appointment date shown maybe cancelled as time goes by ?
actually on friday i can go select a unit for july bto but i've decided to go for the sep bto. so i just don't turn up right? no need to inform HDB hor. my sep bto will still be valid right?![]()
same situation as you. no need. i've already called HDB and check.
my appoint for july bto is 15 nov. applied for sept bto and got a much better queue number. HDB say just dont turn up for the first one if u want to get the sep one.
if u decide to take the july BTO and selected a flat, e sep application will automatically be cancelled. same goes for july one. u dont turn up, automatic cancellation. but if sept u have the opportunity to select and u dont turn up, considered no more first timer alrdy.
ohh thank you! i also gotten a better queue number for sept bto. next week can select alreadysame situation as you. no need. i've already called HDB and check.
just got my package for 4room amk. queue number 12+.
there are some parts that require the input of myself and wife. should i fill up now or go there on my appointent date on dec 2nd then fill up?
Jul BTO for which area??
But still can go for nov bto? If reject July..gt sep one..
