Sep 2012 BTO
Thanks bold10
Having an appointment means I definatly have a chance to select a flat?
Nobody can guarantee a definite yes but there might be a chance if 100++ opts out. Having a chance to select is 1 thing, but selecting a unit of your choice is another.
sgsoftware
Thanks bold10
It does not mean definitely. It just mean you might stand a chance to select. It is better that you also apply for Nov BTO and see if you can get a good q number.
Maserati
IC.
In that case there is still a possibility that appointment date shown maybe cancelled as time goes by ?
AL_boy
Maserati, yes.. My queue number is also out of range and is given an appointment date. So no choice but to wait if got ppls drop out or not...
APC2012
May i check under what circumstances consider a dropput?
If HDB give u selection date but u cant make it, will they forfeit the queue?
Haha am looking for possibilities to console myself I will get to select! hahaha
AL_boy
Is either the person did not turn up to select or choose not to book a flat.
usagichng
Mi too!!! i'm keep my eyes on the possibilities and as well as going for the nov BT. Jus in case the droppot rate ish low..
i need at least 70% of drop out LOL:s13:
greyspots
actually on friday i can go select a unit for july bto but i've decided to go for the sep bto. so i just don't turn up right? no need to inform HDB hor. my sep bto will still be valid right? :s11:
usagichng
I rmb i saw it somewhere before.. but i cant rmb. How do u all go abt view the q number tat has been served for todae? can it be done??
uhuglu3
same situation as you. no need. i've already called HDB and check.
my appoint for july bto is 15 nov. applied for sept bto and got a much better queue number. HDB say just dont turn up for the first one if u want to get the sep one.
if u decide to take the july BTO and selected a flat, e sep application will automatically be cancelled. same goes for july one. u dont turn up, automatic cancellation. but if sept u have the opportunity to select and u dont turn up, considered no more first timer alrdy.
Kelvin_87
Jul BTO for which area??
greyspots
ohh thank you! i also gotten a better queue number for sept bto. next week can select already :D
yoohoo
But still can go for nov bto? If reject July..gt sep one..
Chevalier
just got my package for 4room amk. queue number 12+.
there are some parts that require the input of myself and wife. should i fill up now or go there on my appointent date on dec 2nd then fill up?
Kelvin_87
fill them up now, there are several things need to be completed. If applying under MCPS still need parents signature
