No wonder so many people choose 525 for TP but from the model. I feel that people from block 511 service yard should be able to look into your flat given the angle of block 525 and 511.
I guess some price to pay for reduce noise lvl
One question.
If I am a chinese and my other half is a Others.
Can I select flats for others or for chinese?
Are multi-storey carparks very noisy? I'm looking at stacks just beside the carpark, thinking of units maybe about 5 floors and above the top floor of the carpark. Oh and apparently the carpark has a garden roof.
I'm not sure if this is a good choice. Could someone advise?
I prefer the yard wash area windowless , bright & with lots of Sun. TP do not have balconies. Will use my yard to sunbathe .That not my great concern.
Most of the time the service yard suppose to be quiet. If this is from living room to living room, then it may be a concern.
I heard in Hong Kong, the neighbours can shake hand in their kitchens.![]()
Bro, I guess the best is you enquire from HDB.
Cos they will give u the best/ correct answer.
tried calling them today. the voice machine bring me all over the place expect the customer service staff
One question.
One question.
by default, it follows the guy. but you can make a request to your csm to follow the lady.
same situation as you. no need. i've already called HDB and check.
my appoint for july bto is 15 nov. applied for sept bto and got a much better queue number. HDB say just dont turn up for the first one if u want to get the sep one.
if u decide to take the july BTO and selected a flat, e sep application will automatically be cancelled. same goes for july one. u dont turn up, automatic cancellation. but if sept u have the opportunity to select and u dont turn up, considered no more first timer alrdy.
It's termed "cancelled" on the day u selected yr unit fm whichever bto it is. It won't be "auto-Xxl" when u apply &/or a Nov Q is issued.hi guys!
So it seems like it is possible to apply for the Nov BTO even when I have a q number for the Sep BTO? Our q number is rather lousy, have not even received the starter pack. However, if we do apply for the Nov BTO prior to our appointment date for Sep BTO, doesn't the q number I have currently gets automatically void? Just want to make sure, since I am still in the range for the total unit for the Sep one. TIA!
hi guys!
