Head/earphones Recommendations Thread
PauseZ
Need a recommendation please! :)
- your rig Galaxy Note 2 / Galaxy S2
- What type of usage Music
- File format used in your source Mp3
- Genre of music you listen to kpop, pop
- Headphone / earphone type IEM
- Other requirements android remote compatible. Durable. Using a UE 200vi(like the durability alot) but the angled jack failing so abit hesitant for another UE
- Budget 100 or less
TeamStereo
Suspended
- Your rig (Ipod touch)
- What type of usage (Music,videos)
- File format used in your source (Mp3)
- Genre of music you listen to (Pop,EDM,acoustic,vocals (wide variety))
- Headphone / earphone type (IEM)
- Other requirements (if any) (No need for mic etc but if possible, sturdy build and comfortable as i tend to sleep with my earphones :p)
- Budget (in figures) (50 - 100 sgd)
Oh yea, I found soundmagic's E10 through some reviews, is it exceptional for its price?
Very good for its price =)
- Your rig: Ipod touch
- What type of usage : Music and videos
- Genre of music you listen to : all variety, pop, rock etc
- Headphone / earphone type : IEM
- Other requirements: Current earpiece is klipsch s4, been using for close to 1.5years. Sturdy and durable.
- Budget : Less than $100 or the cost of klipsch s4
Should i get a new klipsch s4 or try another new brand?
Thanks for your advise!
Can try Fischer Audio Consonance or Sennheiser CX300ii
Is the AKG K550 a worthy upgrade from ATH-M50?
I like the sound of the M50, but would like to try something new once in a while. Wondering if the K550 will give a noticeable improvement before I take out my wallet.
Do try it out but I find it more refined compared to the M5 =)
Android remote compatible as in the mic can be used?
PauseZ
Mainly the music controls. Mic not really important
silvernoy
you could try the final audio III at jaben.
my friend got it and he is enjoying it.
StyL3-Ivan
Need recommendation....
- Your rig (iPhone 5)
- What type of usage (Music,Jogging)
- Genre of music you listen to (Chinese pop)
- Headphone / earphone type (Wireless)
- Other requirements (if any) (comfortable, gd sound quality & connection)
- Budget (in figures) (100 - 200 sgd)
PauseZ
Asking on behalf of my friend
- Your rig (iPod Classic / HTC One X)
- What type of usage (Music, Running(lots))
- Genre of music you listen to (Pop, Classics, Ballads)
- Other requirements (if any) (comfortable, sports-friendly, sweat resistant, ear supports so doesn't drop out?)
- Budget (in figures) (200 SGD)
Thanks in advance!
TeamStereo
Suspended
Thanks in advance!
Both of you can try the new Sennheiser sports earphones =)
Can see the list here
fifoent
- What type of usage (Music,Movies, TV Shows)
- File format used in your source (Mp3, Mp4)
- Genre of music you listen to (Kpop)
- Other requirements (if any) (good sound quality & minimal external noise)
- Budget (in figures) (<$40)
TIA :)
Emospence
TIA :)
Dunu Trident.
kaixax555
TIA :)
Vsonic GR99
Empiricism
Any recommendation?
Your rig (Asus Xonar DX)
What type of usage (Gaming, music, movies)
File format used in your source (MP3)
Genre of music you listen to (Everything. But prefer a earbud with lesser artificial bass)
Headphone / earphone type (Earbud)
Other requirements (Supports 5.1, is it even possible for earbuds?)
Budget ($150)
dametcy
Hi,
Appreciate your recommendations for the following:
Your rig (SIII, iPad)
What type of usage (music)
Genre of music you listen to (jazz, pop)
Headphone / earphone type (in-ear)
Other requirements (mic)
Budget ($400)
Thanks in advance!!
TeamStereo
Suspended
but not wireless?... i dont like the wire swing here & there when running. :(
Sorry about that =)
Can look at the Jaybird Freedom JF3 and also the Plantronics Backbeat Go?
If non in ear type can try Jabra Sports BT.
Any recommendation?
Budget ($150)
Haven't seen earbuds with 5.1 surround sound so far =)
Hi,
Budget ($400)
Thanks in advance!!
Can try the B&W C5
If don't mind, can get the Shure SE425 and get the mic cable. The earphone itself is $409 but the cable is $109. =)
IAMNOOB
Any Recommendation? I currently thought of se215
- Your rig: Note 2 and iphone
- What type of usage: movie and music, but mostly into music
- File format used in your source: Mp3
- Genre of music you listen to: Pop, House music
- Headphone / earphone type: IEM
- Other requirements: -
- Budget: $200
JosephK
Recommendation needed
Hi, need your recommendation
- Your rig (Samsung Galaxy Note 2)
- Other requirements (if any) (Needs to have remote that will allow me to control the volume and use as mic)
- Budget (in figures) (100 - 300 sgd) (Don't mind paying more if the earphones remote can work with iphone and android)
TeamStereo
Suspended
- Budget: $200
The SE215 is a good choice and once of the cheapest for something with detachable cable.
yihao93
Your rig: itouch and fiio e1
- What type of usage: movie and music, but mostly into music (on the go)
- Genre of music you listen to: Pop ( eg maroon5)
- Other requirements: prefer bass . noise cancellation.can wear for long periods(ears not pain) doesnt drop off easily (if possible , those that doesnt get tangled ) can be bought in local store.
- Budget: $150
kaixax555
Fischer Eterna or Fischer Consonance
both are quite readily available as of now (not sure Stereo carries them or not, but I saw gain city having the Consonance and probably Eterna)
Eterna's shell is quite large but still pretty comfortable
