mqz512
- Nov 6, 2001
But it's a crapshoot which case will work. Some smooth flat surfaces won't stick, but some that looks like it won't, with powdery surface works. No way to tell for sure until u stick it on and use it.
What a rip-off!
As you can see below, I feel this Tridea is really a fitting and good looking case.
the 2013 edition is just new colour choice instead of just B&W
The A/B type is just describing how u can use BR, flip the ring both ways and not just rotate (look at the pic again)
BR + PRC made KR branded TPU i used earlier
www.hardwarezone.com.sg - View Single Post - GALAXY NOTE II ACCESSORIES
BR with SGP i used with Note1
www.hardwarezone.com.sg - View Single Post - Galaxy Note Accessories
updated pic fr some kr site, hope it appear at gmkr soon
Yes, the A/B depiction certainly meant to explain the 180 degree flip. Could have used a better description and picture though.
It does seems besides BKR 3 has 2 new colours, it is also indeed thinner than BKR 2 if Google translation works right.
"It is a version-up model of Bunker Ring 2. Becomes thinner..."
Amazon.co.jp*F New Bunker Ring 3 White *y‘S4*F*z iPhone5/iPhone4S/iPad mini/iPad2/iPad/iPod/GALAXY Slll ƒXƒ}*[ƒgƒtƒHƒ“*Eƒ^ƒuƒŒƒbƒgPC‚Ì—Ž‰º–hŽ~*EƒXƒ^ƒ“ƒh‹@”\*Eƒn*[ƒhƒP*[ƒX*ã‚©‚ç‘•’…‰Â”\ *y*³‹K—A“ü•i*zUDBR3WH002: ‰Æ“d*EƒJƒ*ƒ‰
"The new Bunker Ring 3, thickness 1mm, when folding ring product was thin 3mm thickness of the base foundations compared with Bunker Ring 2."
AppBankStore : Bunker Ring 3
Too late. My friend just came back from Korea holiday. What a waste.
Must find other ways to buy.
Specifications:
● Net Weight : 100g
● Dimension : 80 x 75 x 50 mm
● INPUT: DC 5V 500mA
● OUTPUT: DC 5V 500mA
hi all. does anyone have any reviews about this folio case by spigen sgp? while i like the simple design (no unnecessary fastener clip), i am afraid it is potentially not durable.
my gripe is that the color range quite limited to pink blue black.
this one has a similar design too. i just share the same concerns. so any reviews?
working in the construction industry.
is this bunker ring 2 or 3 ?
qoo10 listing
I checked the specs for dock that charges just one phone (not the dual charger) hor.... it says:
500mA nia leh. Does it mean it's gonna charge super slow for our Note 2?
note 2 needs 2A
I know... if I use my 1A charger to charge while using the phone, the batt % like maciam not moving one... some times will drop some more. =_=
I squint squint, I think I see 1800mA? Then how come the eBay seller put 500mA siah...![]()
