Head/earphones Recommendations Thread
Jango
Recommendations please!
- Your rig - Blackberry, Galaxy Tab
- What type of usage - Music
- File format used in your source - mp3
- Genre of music you listen to - Electronic - House, Dubstep, D&B
- Headphone / earphone type - IEM
- Other requirements (if any) - Tight, deep, thumping bass is a must
- Budget (in figures) - <$150
Thanks!
Emospence
- Your rig - handphone & Xonar DX
- File format used in your source - FLAC
- Genre of music you listen to - Most genres (classical, rock etc)
- Other requirements (if any) - Slightly more bass than DBA-02, but competitive clarity at mids and highs
- Budget (in figures) - <=$250
Currently looking at XBA-03/04 (due to the price slashes, but heard the highs are worse?) and TDK BA200. Haven't listened to both of them yet though... awaiting recommendations before heading down to try :)
BA200 is worth a try
SeraphicEtain
Hello, I read through the thread and would appreciate some recommendations from the experts here.
- Your rig - iPhone 4S and laptop, possibly a Macbook Pro too.
- What type of usage - Music and videos.
- File format used in your source - MP3, AAC, AVI, MP4 and FLV.
- Genre of music you listen to - Classical, orchestra, pop, rock, R&B among others.
- Headphone / earphone type - Headphones (both on ears and over ears)
- Other requirements (if any) - Has remote control and preferably mic for skype though it's not a must.
- Budget (in figures) - Up to $200.
Thanks very much. :)
LouisLoh
Try to wait and see what deals turn out for Black Friday. If nothing good still can head down to SITEX on Sat/Sun. Or IIRC Stereo has been matching event prices at their retail stores.
TeamStereo
Suspended
- Your rig (Note 2/Walkman F
- What type of usage (Music,videos)
_- File format used in your source (Mp3/Flac)
- Genre of music you listen to ( Pop/Classical/J-Rock/Kpop)
- Wireless Headphone with option to go wired mode
- Other requirements (if any) Must be wireless, previously using Creative WP350, acceptable SQ, but want something bigger cos I've got big head and big ears. The WP350 looks like it's made for babies.
- Budget (in figures) Up to $300
Not many choices =(
- Your rig : Samsung Galaxy Note
- What type of usage : All types of music and videos.
- File format used in your source : (Mp3)
- Genre of music you listen to: Most genres.
- Headphone / headphone'' Dont really mind
- Other requirements (if any) Prefer to be able to kept in a storage box to protect the IEM.
- Budget (in figures) Around 100 SGD
Lost my UE 200 and I didnt managed to find it back so I will have to get another one that is similar. Just asking, is it ok if there's no storage box for the IEMs because AFAIK,most do not provide a box for you to store your IEM. The only one I know of is Ultimate Ears. Thinking of getting UE 400 though.
Other than the UE 400, you can also consider the Fischer Audio Consonance =)
Thanks alot teamstereo
No problem! =)
Thanks for the advise. Will give those recommended models a look.
See you soon!
Caitlyn
Hi Please recommend~
- Your rig - HTC Sensation
- What type of usage - Music and Videos
- Genre of music you listen to - pop, rock
- Budget (in figures) - below $250
Thank you.
Rustify
- Your rig iphone 5, mac air
- What type of usage music, videos
- File format used in your source mp3
- Genre of music you listen to Pop, instrumental
- Headphone / earphone type headphone
- Other requirements comfort for long hrs usage(VERY IMPT), large soundstage, outdoor and indoor usage
- Budget around 250
i am using iem westone um2, but feel the soundstage is not wide enough.
nuclear_pup
Can advise if the shure 215 is a good switch from klipsch s4 ? Using it on iphone for mp3 or probably on note 2 for flac.
Emospence
Yup. But for the price I'd rather get Yamaha EPH-100, or see if sitex got BA200 promo
l0uisVuitt0n
hi all, please recommend... :s12::s12::s12:
- Your rig: S3, ipad mini
- What type of usage: Movie and music
- File format used in your source: mp3
- Genre of music you listen to: all sorts
- Headphone / earphone type: IEM
- Budget: 200-250 (of cause the least the better) :s13::s13::s13:
thank you all
SoulEraser
Logitech Wireless Gaming Headset G930 with 7.1 Surround Sound
Only $69.99 USD and ships directly to SG!
Local retails for at least $180 SGD. Best price yet ever!
Product Features
  • Gaming-grade wireless: Reliable lag-free performance with up to 40 ft. wireless range (Actual wireless range will vary with use, settings and environmental conditions)
  • Immersive 7.1 surround sound: Advanced Dolby technology delivers detailed positional audio
  • Three programmable G-keys: Customize with one-touch commands over chat clients, voice morphing and more
  • Noise-cancelling boom mic: Reduces background noise and auto mutes when rotated up
  • Works with Windows-based PCs
Most Helpful Review on Amazon:
R. Goan said:
First, off, I've only had this headset for a day. I can't really go into detail about sound quality, how good the surround sound is, etc. However, I feel like I need to clarify a couple of things.
There are two major issues that people have been complaining about with this headset: the "flimsy plastic" joints holding the ear cups on, and the lack of a graphic equalizer. Please disregard anyone who mentions either of these two "problems," because it is completely false.
If you look closely at the ear cup joints, yes, there is plastic there. However, if you pay attention, the plastic isn't actually the part that's moving. It's merely a covering for the actual joint. On the back of the box, under "Durability," it clearly states that the joints are made from an aircraft grade aluminum alloy. This is a very well made product guys, I get no sense that, if treated properly (take your game rage out on something that costs a bit less, children) it will ever break on me.
Now, I'm not quite sure why people are saying there's no graphic equalizer, and that they are limited to bass and treble adjustments. Directly below the bass/treble bars, there's a big button that looks like a graphic equalizer. If you click it, guess what happens. Yep, a 10 band EQ pops right up, complete with preamp volume adjustment. If you have this turned on, it grays out and overrides the bass/treble adjustments.
Now that I've cleared that up, I'll give my one day impressions on the product.
Super comfortable. I have a fairly large head, and yes, the headset does squeeze a little tighter than what you might be used to, but that's because the headband is made of metal and not cheap plastic. It's the squeeze of quality, learn to love it. It's not a bad thing at all, you just might not be used to it. After a few days of breaking it in, I doubt I'll even notice.
The sound quality seems fantastic so far. I'm still working on getting it to sound just right with my game of choice, TF2. With movies, music, tv shows, etc, it's just amazing. Crystal clear, rich, amazing sound.
I initially had problems with the mic, people in Team Fortress 2 were telling me that it was cutting out, and screwing up sound for everyone (if you've ever played the game, you know what I'm talking about). This was fixed by turning the mic gain way way down. I've been so used to mics that are super quiet, so I had windows set to max out and boost mic input, and maxed out mic input through the game as well. Turned the levels down quite a bit and presto, clear as a bell.
One thing I don't like, the mic level resets itself every time I unplug the headset (rather, the usb dongle) then plug it back up. It remembers every other setting, just not mic gain. I've solved this by setting one of the G keys to reduce mic gain, so if I ever launch a game and accidentally leave it set too high, I can easily fix it on the fly.
Speaking of the G keys, I was kind of disappointed that they work with ventrilo, but not teamspeak. No big deal though. Still, I was hoping to be able to sit on my porch and chill in our TS channel and be able to chat with people. (I have to go outside to smoke here...ahem >.>...you know what I mean.)
The wireless range and battery life really seem to be just as good as advertised, which was a very nice surprise. I can go anywhere in my house and still have completely clear audio. The majority of my front porch gets signal as well, and that's going between three walls. Last night I went in game with only a partial charge, the software said 7 hours of battery life left. I played a little over two hours, left game, and it said I still had five hours left. Good stuff.
I love this headset. Completely. After years of frustration over broken wires ruining headsets, I could not be happier with this product. If you've got a nice, functioning headset already, like a g35 or whatever, I couldn't justify telling you to purchase this. However, if you've got a cheap POS, or if you're in the market to buy a new headset because you rolled over your current pair's wires one too many times with your chair, I couldn't recommend this enough. I've never spent this much money on one before, I've always been in the 50-70 dollar range. Dropping 160 wasn't easy for me to do, money is tight these days. I don't regret the purchase at all.
Empiricism
Your rig (Asus Xonar DX)
What type of usage (Gaming, music, movies)
File format used in your source (MP4)
Genre of music you listen to (Everything)
Headphone / earphone type (IEM)
Other requirements (High level of isolation + balanced armature)
Budget ($200)
bLue_bAbe
Hi people, would like some recommendation please~
- Your rig: Iphone4
- What type of usage: Movies but mainly Music
- File format used in your source: MP3
- Genre of music you listen to: RNB
- Headphone / earphone type: In-ear
- Other requirements (if any): mic for Iphone or volume control is there is any and prefers heavy bass
- Budget (in figures): S$20-30
-Colour: Preferably green or if not black
I am only a noob soft user, so looking for something good and worth the price so hope to have your expertise to help please~ Looking to buy in amazon for the black friday sale~ :)
kaixax555
thank you all
Vsonic GR07 (either one is fine), BA200, Brainwavz B2, SE215
Vsonic GR07 has very sweet mids
BA200 is pretty detailed and musical, lively presentation
B2 great clarity and detail but can be harsh for some
SE215 if you like more bass
kaixax555
Budget ($200)
As above, BA200 or Brainwavz B2 and also Rockitsounds R-50
