The Hair Thread - Part 1
mgbymgbymgby
hair soft,thin,straight very difficult to style. :(
if really no choice then...
dumborghini
Anyone know how i can get my hair to be free flowing like those kind of model hair? WHich hair products are the best? Pls recommend a hair salon in the acceptable price range! Thanks!
fullguard
any idea what hair colour suit a tanned asian male? head shape is oval but face larger than average size.
would brown be ideal? but later too close to my skintone abit weird...
mgbymgbymgby
Depends on what hairstyle uh, IMO black is fine leh? Else those bright brown? If you wanna have a stand out one
~WindzStriker~
guys ask you all ah.
always see those stars they have semi long hair (example korean stars)
when they style you dont see like the end of the hair (not hair root) one by one pop out very ugly. their hair all stick together and fall nicely in place
is it they do soft rebonding ?
frinters
I have thick, coarse hair that tends to stand up all over the place when it grows long. It seems like the only way to make it look halfway decent is to cut it every 3 weeks, which seems a bit excessive. Can anyone recommend a good hairstyle or a stylist who is good at styling this kind of hair?
~WindzStriker~
duno our hair same anot.
my hair some thin some thick, combined thickness de, so can see the hair end curling out like damage lidat if I nv use hair mask for a long time
kampong boi
oh windzstriker also come to fng =:p
I also think is soft rebonding, and it can be due to their climate that softens their hair naturally
mine is also the same, just that it is more unsightly on the sides, no choice, either you cut or do rebonding to let it fall instead of letting it stick out
