[ICS] Official Samsung Galaxy Note N7000 Ice Cream Sandwich discussion thread
touchme
even with Photo Editor installed, still cannot run when Photo Editor is selected. for now just use QuickPic viewer, can choose your fav installed editor(s) from there. Editor can try free PicsArt Studio.
acty I'm referring to the direct edit button from 'screenshot captured'in the notification bar.
touchme
change default Gallery viewer to QuickPic.
Settings>App Mgr>All>Gallery>clear default
Install Photo Editor(file here), then boleh direct edit.
thks ATN, seems like the photo editor has changed a bit, added decoration & stickers, but no painting/writing tools..or did I miss sth?
What painting/brush app to rcmd?
<EDIT> Found it. Good enough, thks
touchme
Whaa.. I itchy Hand decided to change to leaked JB. Kaoz damn power!
Describe 'damn power', review pls.
I just realise that remove bloatware like Samsung apps and some background services, ironically does injustice to battery drain. Reflash and back to normal.
moozmoow
wa, explain more please! maybe thats why my battery draining lol. :s13:
touchme
i dunno, i just removed several samsung and bloatware, the list of unknown system services also quite long....though the device still works, I got a feeling a few unremoved apps are constantly seeking the missing services, that cause the device to be hot most of the time....as in the tech details i can;t fillyou in, just suspecting..
Anyway, I dunno if ppl using XXLSA leak rom, are experiencing reboots that refuses to go into Samsung logo screen...I xp it a few times already. After dalvik and cache wipes each time, it's boots fine. This last time now..just unrecoverable anymore..wonder if it;'s a malicious app.
Looks like must factory reset and full wipe, and re-flash.
Anyone else xp the same thing?
ATN888
kena only once, tried remove battery, clear dalvik/cache all no luck.
Suspect i freeze too many samsung bloat.
Did a reflash then after 3xWipes, Mount/Format-system,data,cache,preload.
So far touch wood, no major drain or lag, no mtp issue.
Just up kernel to 3.71.
Edit:
nice! LSA test rom is out!!!
ATN888
anyone here tried the Odin LSA? how it is compared to eybee's?
almost wanted to flash it but hentak kaki when I saw they trying to dump LSC.
touchme
Edit:
Fedup with my unbooting LSA, forthe 5th time, went back to RRv3, which ironically kind battery and smooth for me, ...(maybe cos it's 1st batch set)
do feedback on the Lsa test rom. tks.
kopitalk
My experience using PC Odin XXLSA, it is definitely smoother compared to XXLSA deodexed zip, eventhough they're the same built. Maybe because it is WIPE until very clean. Flashing this via PC Odin will not trigger yellow triangle or custom binary counter. However modding is quite tricky because it's stock ODEX. I tried to apply multi-window mod by manually copypasta the .apk and .jar and deleting the corresponding .odex, resulted in bootloop... Maybe modifying the updater-script to delete old files will help.. I'll try later when got time..
Those who like stock, it's recommended.. otherwise wait for a while until XXLSC comes :)
Rooting is the usual routine:
1. Download PhilZ v3.71 LSA in .zip and store in external-SD
2. Reboot to stock recovery
3. Install zip from external-SD
4. Press and hold power button to reboot system
Rooting process will not invoke yellow triangle or custom binary counter.
touchme
Ultimate v5 for lower ram and battery juice, zoomable Gmail 4.2 and jellybean touchscreen camera, and ota updates.
Upgrade to whatsapp+ at the same time at xda.
ATN888
My experience using PC Odin XXLSA...
Thanks for sharing.
I'll give my Note a break & wait for LSC:)
Edit:
Samsung updating test rom every week now???
Downloading LSC now but just saw someone with a "LSD" screenshot!
Not that I'm complaining :)
