pOki7
- Jun 8, 2002
WelcomeThanks for the review.
How the remote control?
ok - i checked it out on Tuesday. it's the real thing but he only had a display set left which he didn't want to sell. also dont know when more will be coming in.
btw, Cybermind is selling it at $139 - still cheaper than Amconics but prob no cloudtv app
Basically I think it should be the same minus the extra USB ports, optical out and RJ-45 connector...hopefullY the G4 works as good as the X5
haha.. you never include the DHL fees of SGD27.. bo hua.. might as well buy from aliexpress at least $15x inclusive of DHL already..
Use a bit of logic la.. if in Spore why would the seller bother to offer such an expensive option like DHL.. obviously it's most likely overseas..This is in Singapore leh, maybe can arrange self collect mah...![]()
Well, you can always check the seller's rep. I think diamonds are more reputable than medals..Are sellers at Aliexpress reliable? As in will they take my money & never deliver my goods or I end up with a Dead on Arrival product?
Not worth. How about iMito MX1 Jellybean. No one interested?
Use a bit of logic la.. if in Spore why would the seller bother to offer such an expensive option like DHL.. obviously it's most likely overseas..![]()
Most sellers there offer a one year warranty..
Must look properly.. egBut the diamond supplier charges USD$10 more for the product & another USD$18 for delivery by DHL so that tracking is possible.The medal only supplier charges USD$1.9 for delivery by DHL. So the diamond supplier is around ~S$34 more expensive.
I chatted with one of the seller regarding what kind of power adapter will be provided to be used in Singapore 240v 3pins plug. He said a UK-plug will be provided for shipment to Singapore. There won't be any problem with the power plug & voltaged used of 240v in Singapore versus 110v used in China?
1) Seller A - $105 (DHL $15)
2) Seller B - $115 (DHL $5)
Prices are stated with free shipping. China is also using 240v I assume same as UK/Sinkipore
I bought from aliexpress. Let me be the guinea pig. But 3 weeks later then know.
Why 3 weeks?
