Proposal Ring - Part 2
masschaoz
bought an Ideal Super Cut 1.56ct G VS1 from Amy at JannPaul..
first visit there.. but totally sold when i compare the quality and price against a same size lazare.. hope i got it right?
hollander
Glad I found this thread.
Can someone tell me if this diamond is a good buy? It is from bluenile.
$12,393
GIA Report Check
GIA Report Number: 2135777040
Report Type: GIA Diamond Grading Report
Date of Issue: August 26, 2011
Round Brilliant
Measurements: 6.54 - 6.56 x 4.04 mm
Carat Weight: 1.08 carat
Color Grade: F
Clarity Grade: VS2
Cut Grade: Excellent
Proportions
Depth: 61.7%
Table: 57%
Crown Angle: 35.5°
Crown Height: 15.5%
Pavilion Angle: 40.6°
Pavilion Depth: 42.5%
Star Length: 50%
Lower Half: 80%
Girdle: Medium to Slightly Thick, Faceted (4.0%)
Culet: Small
Finish
Polish: Excellent
Symmetry: Excellent
Fluorescence: None
to help you further:
HCA Score of 1.4, not bad as it is below the 1.5 suggestion.
Grading report is more than a year old, still okay.
If you have the image scopes it will help you alot.
hollander
It is a good buy and i'm sure your are happy with it...and your soon to be wife will be very happy as well for a 1.56ct...huwowwwwwwwwwww :s13:
hollander
Hi,
i am very new to Diamond and was quoted the following for 2 diamonds.
Super Ideal Cut
0.78 F VVS2
$9500
Solasfera
0.78 D VS2
$9400
Seems like it's really quite a jump from the quotes that i see from other forumers.
Does VVS2 really command such a high price, is Solasfera worth the extras, are the price a bit high for a 0.78, which stone is more worth it and should i consider other stones?
.x7 .x8 .x9 are prime cuts, being a prime cut adds up additional value.
yvette
Hi,
Super Ideal Cut
0.78 F VVS2
$9500
Solasfera
0.78 D VS2
$9400
hi i think the solasfera is a very good buy!
mine is a 0.78 too! specs E, VVS2 and it cost $11k+
the price quoted to you is quite attractive... did diamond value drop a little these days?
if you can afford i think it is worth it ;)
blackwire
Is the spark really very obvious between a super ideal and a solasfera?
Seems like a VVS and a VS really got a big price diff.
blackwire
hate to spoil the market, but i think super ideal cut for $9400 is really expensive. Chop chop chop.
bluenile.com/sg/diamond-search?track=head#diamonds_pid=LD02479305
i also find the price very high, should be a big diff between a VS and VVS bah.
blackwire
I believe after you have visited JP, you should be well educated and have adequate knowledge to source your own Super Ideal.
I would advise not to limit yourself to just one jeweller, give yourself more options by visiting more jewellers to compare the quality and price.
Any others to recommend?
blackwire
the 0.78 carat Solasfera seems like a better buy.
D color is great
Clarity need not go to VVS2..VS2 will appear same as VVS2.. so VS2 is great also
I will go for solasfera any time..
in this case with same price, solasfera look like a better buy.
i am wondering whether the spark of the solasfera worth the additional money spend? or should i get a bigger diamond instead with the same spec.
midnightblu
haha, is it a proposal ring? actually i think it is a matter of personal preference.. if it is a proposal ring, might be best to try and find out what your gf prefer.. e.g. would she rather a big and sparkly diamond, or a smaller but super sparkly diamond.. :s22:
if u ask me choose between e.g. 0.7 solasfera with super good specs vs 0.8 57 facet diamond with super good specs, of course i prefer 0.8 la, look bigger ma.. and it is still super bling.. lol
and i heard that jp solasfera supposed to be 20-30% more exp than normal 57 facets btw... if you got a lot of $, then buy big and super sparkly lor :s13:
midnightblu
i thought a .9 is a prime cut cos it is nearer to 1.
.7 and .8 also consider prime cut?
What is consider a prime cut then?
eh.. actually that time i went love and co, they also don't have 0.8 ideal cut for me to see.. they say it is more rare/low in stock because the diamond cutters prefer to sacrifice on the cut quality and cut the more popular sizes like 1.0carat.. private jewelers would have more sizes to choose from tho..
jchowjs
So glad i found this thread:s12:
i barely just started Part 1 of this thread but can give me a headstart and recommend some retail or private jeweler???
My budget is 10K...
if going for Tiffany....how much should i set aside???
TIA :o
You can definitely get a decent enagement ring from Tiffany's at that price. I was at the shop earlier and the sales lady shared that in December they have a better assortment of diamonds. Good luck
alfiee
Ooo how much was it?
I got a 1.59 Solasfera F VS1 for my wife too.
icyboiboi
My Proposal Ring
On the day.. 12th December 2012. With 12 Honda Cars, we set to surprise my dear Jolyn Hsieh at her workplace. Proposal 12pm 12min 12s, which makes everything to be....... 12.12.12, 12cars 12.12.12 and ofcoz not forgetting 12 red ROSES
https://www.facebook.com/media/set/?set=a.10152339249070384.947969.711035383&type=1
