Nov 2012 BTO
Des126
I guess if there are 100 applicant an each application got 2 chances.. Then there will be 200 queue no. in total.. Then they will give u the smaller number of the 2 chances.. Eg. 90 and 150.. Ur number will be 90..
Just my theory on how I think it work..
in this case, the first 100 queue numbers doesnt mean will consists of 100 applicants. Am i right to say that?
bearine
Yes.. But I guess there will be some sort of rearrangement to make it fit back to 100 application..
lzjlee
The total unit of 5 room is 716. 15% is for 2nd timers so the total unit will be around 107.
Does it mean if i'm a second timers with a queue no of 150 also cannot guarantee for a unit as it will depend on how many are 2nd timers out of the front 149 before the queue no.150?
Yes. U r right that 107units r for 2nd timers. The number u see now is the position of ur queue. Meaning u r the 150th applicant to select the unit. 150 is a very good number btw. Haha. Congrats
jiayan
Hi my queue no is 428 out 716. But beside it indicate
Estate : Sengkang (Rivervale Delta)
Flat-Type : 5-room
No. of Flats : 716
Your balloted queue position : 428
We don't get to choose between compassvale mast or rivervale delta? Cause at when I apply they group this category together
n1ef5ng
Flat-Type : 5-room
No. of Flats : 716
Estate : Sengkang (Compassvale Mast)
Flat-Type : 4-room
No. of Flats : 890
Your balloted queue position : 576
What it means then
Des126
sorry i just take it as example. I'm a first timer and i am getting 421. Not sure how's the chances to get a 5 room from Compassvale Mast.
jiayan
Flat-Type : 4-room
No. of Flats : 890
What it means then
Means u get the premium units. I thought we can get to choose whether we want standard or premium. But is they allocate to us.
n1ef5ng
This is the assumption u made right. I think the bracket doesn matter. Afterall it is /880 meaning they are putting two projects together.
However I hope u r right cause I do really want compassvale
twinraven
I'm confused as well..
Flat-Type : 4-room
No. of Flats : 890
Your balloted queue position : 598
Does the bracket means that I get to choose compassvale only? But the the no. of flats suggests that the 2 are grouped together.
Des126
Perhaps can try to verify with HDB.
deranged89
Guess not its lumped together. Depends on the ethnic quota and if all the units are snapped up.
