albertlee
- Jan 1, 2000
router : Asus N15U
switch: D-Link 8-port GB switch
PC: AMD X2 series (cant rem model) + 4GB ram on Windows 7
Tks for the info.
router : Asus N15U
found this test benchmark while I was considering to buy the DNS-320L
D-Link DNS-320L [DNS-320L]: specifications, reviews, discount offers and more | Hardware.Info United Kingdom
thanks for the advice i manage to connect it now.
But i notice my transfer speed is only 2mb/s.
i try difference file size still about 2mb/s.
I set to Standard volume. i connect to 2wire port 1-Gbit.
Does RAID-0 transfer fast than Standard volume?
what else can i do to increase the speed?
Fyi, Funan Challenger (Level 6) having a promo for DNS-320L for $99 till 25 Dec , Christmas!
Wonder anyone try the remote webUI access via SSL? I have no problem with normal remote access. When I start to use the SSL way to login, the browser seems to do some loading via https but the page remains blank.
If I use the same method (SSL) to access the webUI within home network, the page can be loaded with https.
yes. I have forward both port 80 and 443 to the NAS in my router. If I accessed using SSL within my home network, I can access. But once I access it remotely, the web page is totally blank.
Does the normal http access work remotely? And which firmware are you on?
yes, normal http works fine. The firmware is still v1. I think there is no update.
Actually there is new 1.01b02 but the release log did not mention anything regarding remote SSL access problem.
Thanks for the information. Realized this firmware is from Taiwan side. Is this applicable to us in Singapore. Dlink seems to have different firmware for different regions.
Actually I may not have described the problem I am facing clear enough. When accessing remotely with my ddns account, I am able to see the webUI login page. This shows that nothing wrong with the ddns account and the prot forwarding. I enter my password and selected the SSL login. Then the browser status shows as waiting, trying to access my NAS. The address bar shows the correct site and it started to load. After a while the status at the bottom of the browser show as done but the screen is still blank.
My feel is something in my browser is blocking the content of the site but still can't find what is it.
