KDK Ceiling Fan
thinking of fixing a ceiling fan in my living room.
anyone can recommend a reliable shop for KDK V56VK.
what is the rrp for this fan ?
thanks!
wongkc
thanks!
My experience with KDK fan is... the fan needs a lot of allowance on the ceiling for the air flow to be effective... else it will be shaking a lot if turn on to the max setting... Not sure if it is the same for other brands but my ID says KDK fan need more allowance...
And there is a slight gap btw the wall and the fan which cannot be covered...
dewydog
thanks!
If you hunt around in Singapore, the best price is about $380, but most places will ask for about $420.
If you go to JB, you can easily get it from RM480.
lcwei96094
We are thinking to bring in 3 ceiling fan and 2 ventilation fan from JB. Not sure will SG or MY custom tax us?
homedriver
KDK fan is proven, I'm also looking but the problem is KDK fan is without light. Anyone know is the fan with light bright enough?
thewiseone
U can check out Crestar fans. They have both AC and DC models, both with light attachments (choice of PLC or LED). U can install 2x18W PLC or 2x9W LED, equivalent in brightness to a typical 32W round fluorescent tube.
most shops quoted me around the range of $448 + $44 for installation.
where is this place that u say $380
homedriver
Thanks but never heard this brand before. WIll find out more.:)
mark lim
bought my KDK V56 from JB. been using it for at least 6hours a day since march2010. So far so good. you can buy 2 fans in JB for the price of 1 here. Who cares about whatever warranty.
remember even if it is warrantied, you have to send it back for repair and in the mean time no fan to use. buy 2 units and just do a quick swap if it spoils. So much better isn't it. warranty support in Singapore is overrated. I always rather buy cheaper than any warranty especially when you can buy 2 for the price of 1.
asisdontknow
3 years back i go to the shop along jalan bukit merah opp the old safra builidng.
I find that buying from electrical shop is $100 cheaper then buying from those shop that selll lights and fans. The model i get is v56.
bakasa2002
the shop is called Maximum Credit or Hong Liang Electrical. TS can call for a quote ...
bakasa2002
keen to know if the stand fan is also cheaper in JB and where in JB is a good place to get them. Thx.
busybody1
thanks!
fan shaking and shaking !!
fan got tick tick sound !!
dont buy KDK ceiling fan..its not like lastime KDK quality...KDK standing fan very good !! 16yrs annd still going strong !!
snipfer
shaking is bcos your installer DOESNT know HOW to fix a KDK ceiling fan!!!
you need to get a certified installer to do the balancing.
