Just got myself a 320L and have been following the instructions at
DNS-320 -FunPlug 0.7 + Transmission for the installation of fun plug and transmission.
There are some amendments to the guide to get it working for the 320L as experienced by some memebers in this thread. Thought I share my experience here for the benefit of others.
1. ssh login will work for the first time. But after reboot, there will be a connection refused error. Need to do the following as discovered by LX2010
Add:
chmod 600 /ffp/var/lib/sshd/
chmod 600 /ffp/etc/ssh/ssh_*
just before the line “proc_start $command”
in the file ffp/start/sshd.sh
2. Latest transmission version has changed from 2.52 in the klseet guide. So need to amend the filename accordingly when entering commands
3. Transmission should launch. Need to fix permissions as advised by albertlee
Create /ffp/etc/fun_plug.local and add the following:
chmod 0664 /dev/random /dev/urandom
4. All is not well yet. web gui will crash soon after giving cannot connect to server error. As advised by
http://forum.dsmg600.info/viewtopic.php?id=5627
edit /ffp/start/transmission.sh
replace: su $user -c "$command -f" with su $user -c "EVENT_NOEPOLL=1 $command -f"
Afternote: I am still getting error after step 4. If I set the variable EVENT_NOEPOLL manually, it will work but once I restart it will be lost. Need to research more.
Afternote 2:
Decided to add the variable after transmission start instead.
transmission_start()
EVENT_NOEPOLL=1; export EVENT_NOEPOLL
if [ ! -d ${TRANSMISSION_HOME} ]; then
Hope this helps fellow forumers!
