Whatsapp on Android
vagus1978
Nope, it's not an option to disable it in the app itself, though I kinda understand why it's not an option. It's a messaging app for fast and prompt messaging, and if there's no visible prompts why is it installed in the first place? :)
That being said, if you are on Android 4.1 or 4.2 (which I don't think is available on ur model yet), they can be blocked manually.
So in summary, no. :(
The only reason I have it installed is because of free group chats for discussion purpose as well as free sending of multimedia files/pics without incurring MMS/SMS count/charges.
Guess I have to wait till I upgrade to the JB update announced recently for my phone.:(
waterballoon
anyone facing an annoying bug? my notifications are not coming up... becoming like iOS whatsapp, must enter the app then can see/know new messages.
vagus1978
hey, wait a minute......if I move the app to the SD card.....will it solve my problem since background process cannot be running all the time for apps on SD cards.
kazuki666
Me too... :(
But its not always lah.
Sometimes msg comes in, but it doesn't show any notification/vibration/ring till I unlock my phone and launch the app. The msg could be like few hrs earlier, not unknown to me...
I am guessing is it because I use atk kill apps too xiong? :p
vagus1978: How do I tell if my whatsapp is installed on the phone or memory card???
potatoface
my whatsapp showing me a msg tt says it is going to expire in 7 days, promt me to purchase now.
And it dont allow me to send msg, i can only receive msg.
Anyone encounter the same?
NWT1978
Anyone encounter this on SGS III?
the status icon is temporary missing...it take awhile to show up
Whatapps version: 2.91035
meekiatah
Apparently when a phone number has been registered on an idevice, this license becomes permanent.
I bought my copy of whatsapp when using 4s and now am using that number on an iNo One and my license is permanent.
ArchSamurai
same sia my whatsapp expiring in 7 days..
registering using iphone, the iphone need reinstall whatsapp?
my android phone need to uninstall whatsapp? or delete account or wat?
Collectible
I put my micro sim into an iphone. Register it, load whatsapp and put it back into my note2.
Had to reinstall because initialising stage took way too long. When I finally register it back, it extended by a mth.
How is it possible to get the extension for a decade?
Mach3.2
Actually just reinstall on a iPhone, then when it asks for a number, just use your number, no need to swap sim cards.
kokchoong
Do you need to change a new itunes account?
Assuming i borrow a iphone from my friend, uninstall whatspp and reinstall with my hp number for verification. How am I to purchase it when my friend has already purchase whatsapp previously?
Mach3.2
Use your friend itunes account redownload la....................................:s8:
kokchoong
Er... I don't understand this part. Pls be patient if I sound like a total noob asking silly questions.
I have done the following:-
1. Uninstalled Whatsapp on my friend's iphone.
2. Downloaded and reinstalled Whatsapp (no purchase required)
3. I used my own HP number for verification.
4. Received a verification code on my hp
5. I activated Whatsapp on iphone using the verification code
After this, i can receive my whatsapp msg on the iphone.
What is the next step I should do to purchase whatsapp on itunes? I just want to make a one time payment on itunes for whatsapp to use on my own hp number. Did I miss anything?
kennyboy
Ur friend already purchased whatsapp from the store. So any number registered on it will be considered a paid "forever" account.
