Asus PADPHONE 2
86technie
Just curious whether you guys padfone 2 battery can last untill the end of the day?
I been using padfone 2 for almost a month now, I only charge it
only during in the night.
Vertix
Been using this gadget for approximately 10 days or so, previously using a Iphone 5. No regrets, good battery life.
But does anyone faces problem with the notification? Sometimes messages and whatsapp received but without any form of notification (Ie. sound/status bar icon)
emo panda
never had this notification problem before..
hbyik01
I hear sound but no notification. Now used NoLED setting. You can try it. :)
tanchunkiat
I really want to know about this as well..
I called starhub's customer service and they told me that the nfc sim card is not compatible with the padfone..
I'm wondering whether it's possible to just change to the nfc sim card anyways.. And only use the nfc services as and when they make padfone compatible..
But didn't get thru from the customer service side.. Wonder if anyone can try this out..
I went to a Starhub authorised retailer yesterday late evening and was told that I could only apply for a NFC SIM card at the actual Starhub Shops. I did not mention that my phone is an Asus Padfone 2.
I am planning to make a trip to a Starhub Shop this afternoon/evening and make a face-to-face query. Will update again.
mohdFaiz
wah suddenly my phone's chassis became loose and can hear the creaking noise.
anyone else experience this issue out of the blue?
It's not like I dropped it or anything..
tcg170980
anyone have problem connecting to 4g? i am on m1
my friend m1 able to connect to 4g my my padfone is unable to get
PsyNidE
i thought that is automatically included? need to pay to get 4g?
its not automatically included and you need to be on a plan that is 4G. For now, 4G VAS is free till further notice for M1.
Take note that if you change from a 3G to a 4G plan, only the highest plan has a 12GB data incorporated into it. The rest of the lower tier plans have lower data usage quota.
mohdFaiz
wah this loose chassis that's causing the creaking noise is really bugging me. I rmb seeing someone else with the same issue and brought it up to Asus.
I have sent my phone to Asus for repair before and they mentioned they changed my motherboard. would that have caused the casing to be loose?
