Good Portable Charger
jason910
Hi anyone can recommend any good portable charger out there that can charge the iphone 5 for maybe like 3 times or so. I am currently using the below but am looking for better ones. Please share thanks
Portable Power 6200 - W3GEAR
deep3lue
I think the better way to approach this question is to go find a few models and ask around who has used what and whether is it good a not.
At least people won't have to second guess what kind of size, design and price is acceptable to you. :)
jason910
Thanks but the reason i ask is because i do hope to see a selection of models that people are using and whether they are good or not. I am a noob when it comes to portable chargers. Even the one that i have is recommended from my friend. Cheers
LonelyMan
Hi jason910,
I have the same charger you used, but I built it via DIY method (e.g. buy case and battery from Ebay separately).
There are some chargers that provides efficiency of 50% to 60% generally, meaning the advertised rating (e.g. 10,000mah) would only charge up to 50% (or 5000mah for example) compared to your iPhone battery capacity (about 1400mah++), in another word 3.5 times).
Another thing to look into is the use of Li-Ion (18650 sized batteries) or Li-Polymer (can be flat shape) like the batteries used in mobile phones. Generally speaking, Li-polymer has higher capacity and more effective use of space in a charger. Charger can remain flat, which can be a plus factor for smaller capacity chargers (e.g. much more portable).
I have used mainly the 4 Li-ion battery, 2 Li-ion batteries and Li-Polymer battery based chargers. I noticed that the 5200mah Andino I bought has only 45% efficiency (for Apple products it is very low as normally they have 60% from my other chargers). Since I was just back from Hong Kong yesterday, I also saw similar (in fact identical design, same dimension) chargers at the Sim Lim equivalent mall that labeled them as 4000 or 4500mah chargers. 4000mah is more realistic (giving a 58% efficiency). Basically, what I mean is while they may labeled it as 5200mah, the actual performance could be affected by component parts or even unreliable rating.
If you need at least 3 times (assuming 0-100%) of recharge, you would need about 1450mah x 3 or 4350mah of effective charge. If efficiency is 50%, you will need a 8700mah charger. If efficiency is at 60%, you will need a 7250mah charger. But there is a trade off between having a larger charger (higher capacity, heavier) vs smaller charger (smaller capacity, lighter).
In the market, many chargers used a 2200/2400/2600/2800mah capacity Li-Ion batteries or some will use a Li-Polymer batteries. A 4 x Li-ion configuration plus case would weight about 250-280g generally speaking. a 2 x Li-ion configuration would weight about 130-150g. Because of accessibility in Singapore plus being in office, I generally used a smaller pack like the Andino 5200mah (I personally believe only about 4000mah), which is the size of iPhone 4S. Overall gives me more than enough to last for a day of 12 hours of heavy non-gaming, continuous use. For overseas, I would bring along the 4 x Li-Ion configuration pack as colder weather causes the battery to last shorter in the iPhone 5. This is very useful when you have a friend that needs the extra power boast.
jq75
Envelop batt booster allows a 180% charge from 0%
One full 100%
Another about 80%
dreamer_toons
One full 100%
Another about 80%
I'm using that too. It serves as a power backup for me though I seldom run out of power on my device. Better still, it has a slow discharge rate and hence I needn't charge it too often.
Shadow04
One full 100%
Another about 80%
I have this also. Used to use this everyday when I was still using Lumia 900/Galaxy Nexus. But seldom use liao after I switched to iPhone 5.
messi1986
Hi jason910,
Can share how u DIY? :eek::eek::eek:
LonelyMan
Buy 18650 batteries like the one below (Panasonic 3100mah)
4pcs Panasonic NCR18650A 3 6V 3100mAh High Capacity Li ion Rechargeable Battery | eBay
Buy portable USB charger case like this (gives me about 27.55whr out of 44.64whr, or about 61.7% efficiency):
5V 2A 18650 Mobile Portable USB Battery Charger Power Supply for Phone MP3 | eBay
Or this gives me only about 22.55whr out of 44.64whr, or about 50.5% efficiency, I need to test again):
Dual USB 5V 2A Mobile Power Supply 18650 Battery Charger Box for iPhone 4S 5 | eBay
I am looking to buy other cases as well as the Panasonic 3400mah 18650 batteries to further increase my capacity LOLx
jason910
Hi jason910,
Thanks for the wonderful reply, am trying to understand more. By anyway is the Eneloop Mobile Booster 5000MAH good? Thanks
LonelyMan
Would not give you the 3 charges or more you ask for. At $60++ I have better options. Took too long to charge (7 hours on adapter, 14 hours on USB).
LobsterX
Try yoobao, newtrent, eneloop.
if you want more charges, go yoobao. go GOOGLE on the capacity and find one that suit you. I have one myself for long trips overseas and when i'm out and about for more then 16hrs.
if you just want something to charge with, go eneloop. slow, but steady.
LobsterX
why you take 7hrs to charge eneloop? when i charge with the supplied charger, i take less then tat to charge from empty to "non-flashing" stage. something wrong with your charger ah? maybe you got faulty set.
jason910
How long did you take to charge?
ABuNeNe
What's the total capacity using these batteries? Am I correct to say it's 12400mah (3100mah x 4)?
How long does it take to charge from 0 to full?
LonelyMan
8-9 hours using a 2A 5V USB output similar to the Apple iPad 2/3/4 charger.
ABuNeNe
How about the capacity? The 18650 batteries and the case add to ~USD$40.
I'm currently thinking of getting this 10000mA which cost ~SGD$40 till I saw you post, how does both compare?
jq75
my supplied adapter died on me.
i use USB to charge overnight, though longer, but still does its job
