waddahell
- May 31, 2004
yeah mine appeared.. wait ah i ss
like this
If pay thru paypal is top 1
If pay thru MS directly using cc is btm 1
tyty very helpful
like this
when I did that a couple of months back, the system fail to register office 2013 as the default program for all my documents. other than that, I don't see other problems with it.anyone ? do u first uninstall your Office 2010 .... or simply install 2013 over the existing one?
wat are the effects if any (not uninstalling 2010 1st)?
That is a common problem with dual installations. Windows and office work from the base assumption that there is no reason to have more than one version of office installed. Therefore, each time you start an app that is a different version than currently active in the registry, it must mean you just installed it and obviously want to replace the currently installed one. WRONG. The fix is a simple registry "hack".
Those who wants to buy the keys, buy them at your own risk!
MS can always invalidate any keys as and when they like. I've once illegally obtained a MS project 2010 key, successfully activated it, only for it to be invalidated few months later.
(btw, i've bought a few $5 keys as well, but i'm not selling any since i don't think it's right to do so)
I just activated my H&S successfully.
I did not receive any refund email and my product keys are still in my Microsoft Store account. The installation links in the account do not work for me.
1. Go to Download, Backup & Restore Microsoft Office Products - Office.com
2. Under "My copy of Office did not come with a disk", click the link just under "Getting Started".
3. Enter your product key.
4. Verify Country and Language.
5. Create or login to existing Microsoft account.
6. Click Install, the click-to-run installer will be downloaded.
(If you want to install 64-bit version, click Additional Install
Options, and change to 64-bit)
7. Run the Installer. (The installer cannot be customized, i.e. cannot choose which folder to install to and cannot choose which programs to install)
I got a ton of keys but only 1 machine and I don't need Visio or Project.![]()
im the one who he sms and i said he was a con man i will not retreieve my word he say he took the risk of 5 dollars but if deal was cancel he would get 5 back so why would he have risk ? and half of retail price ? forumers pls judge
