The Spectacles Thread.
anyone knows what model is this from ic berlin?
Seannie
are those all Less Than Human frames?
atypical, any comments? the hinges dont look too sturdy?
How much do Less Than Human cost?
atypical
The middle one, as the pic suggests, is Less Than Human. Donno how much. The third one looks like Factory 900.
Obviously, people who like these wouldn't care if the frames are stable. But if Factory 900, the frames are stable. Tried a few models before in the shop ...
lunarsong
Has anyone bought specs from JB and do some recommendation?
Anw i am concerned about doing transition len because i will not be able to collect on the same day. Do they do delivery?
Lord_Kang
Any recommendation of brands that have plastic frames like rayban but has better nose pad support??
Prof. Utonium
Can recommend me shops that offer affordable and wide range spectacles for students?
Might be making a few spectacles.
Rimless, Half rim, transition, photochromic and different colours.
Also can recommend frame that is durable? My frames tend to be slanted after some time. Perhaps due to my physical abuse. Drops and sports. Swissflex?
Pocoyoz
Hi
what is HOYA EA60 1.6 lenses?
Is 1.6 lenses suitable for 600 degrees?
atypical
Recently, saw a selection of Superdry frames at Optical 88 Tampines Mall. Very nice. I first saw them about a month ago at my usual optician's, quite like them.
Evisu is another that you may want to check out. Style and branding wise, you decide.
Particularly like the second one from the top :
Lord_Kang
What's the price range? Any idea?
Have u heard of acupuncture london brand??
atypical
S$329 and up,I think. Saw a few Acupuncture frames when passing by an optical shop at Burlington Sq. Wasn't Impressed. Maybe the shop didn't carry nice ones :D
JxXxn.
Hi all,
I would like to ask if all authentic Oakley's come with a Product Authenticity Card?
Icannobif
My Oakley titanium frame got many many paint chips, from original gunmental becoming silver color.
Anyway services avail to refurb it?
Seannie
None. Just leave it as it is, looks seasoned. Specs are supposed to be this way, getting peeled off overtime. Anyway thats how the optical trade earns $. Selling you expensive specs but ended up most of the time you dont really use it till it breaks. You will change it when colour chips off becos most people will bother them to be wearing a off-coloured spec. Which is why most people, if they can afford it, will change spec every year. So sometimes i think whats the point of getting too expensive pair of spec when it cant last you a lifetime of usage.
atypical
Depends lah, some brands' paint work are quite bad. spec espace is another with bad paint work, so I heard.
623MRB1
Would appreciate if anyone can share with me the price indication for Hoya (with SFT coating), Nikon and Zeiss 1.67 Asp progressive lens with the following prescription? What would be the top up for transition or photofusion?
R: -3.25, -3.25, 180
L: -4.25, -3.75, 170
ADD: +1.50
Thanks!
Seannie
i think its a matter of time before paint drops off.
Need to check with you something. U know the plastic earsocks that they use to cover the temple tip? DO they get scratched easily? My Dun plastic temple tip is alreay scratched but the rest of the metal part still remains unscathed & shining .:s11: And do water seep inside those plastic covers?
ohj81
Been using a photofusion 1.5 lens for the past few days, seem clear / brighter than my 1.6 Crizal Airwear Transitions. Though the lens is thicker and more fragile.
