cutiedoggy92
- May 14, 2006
Heres mine, simple one for now
Lai Lai come show!
Lai Lai come show!
Mine
Mine
Mine
Glass widgetWhat widgets are you using? Looks neat.
Hi all, im using nova launcher (hide dock, 10X7 grid) with metro inspired icon Link and glass widget.
bro, i cannot find the metro inspired icon for nova launcher leh.
please kindly give me play store link or download link... the link you gave was for miui, right?
i think his is miui, thats the correct link he gave..i'm using miui as well![]()
Never into theme customization. Can advise how to make it like his/yours? Thank you.
Download the mtz file from the XDA link and rename it to a zip file. Unzip the file, and there will be a file called icon with no extension. Add a .zip extension to that file. Now unzip the file and you'll get the icons in png format.
