Post Your Homescreen here!
Ah Huat
How u guys take the screenshot on your sony xperia z ah :s11:
I also want to post mine leh ;)
doki81
press power button until you see the power off option..u will see the take screen shot..
namezlezz
Heres mine, simple one for now :s12:
Lai Lai come show!
mine
http://
im quite curious y cutiedoggy92 the on screen buttons like diff pattern frm the rest of the screenshots one ar ? Plus its black backgrnd de...docomo version ???
cutiedoggy92
Lol nope, is local set. Cause I using nova launcher
I know le! Lol I posted the wrong screen shot, that was my previous nexus 4 phone, my xperia I make the same configuration too. I edited my post le
teh__o
Is there a way to set a different wp for each homescreen?
Jargon
Download the mtz file from the XDA link and rename it to a zip file. Unzip the file, and there will be a file called icon with no extension. Add a .zip extension to that file. Now unzip the file and you'll get the icons in png format.
1st time using Android here.. How do you change the icons for all the apps on your home screen after unzipping the icons in png format?
